February 5, 2019, 08:05 |
Drag Coefficient undepredicted by CFD?
Aamir Sultan
Rep Power: 8 |
I am simulating a 3D airfoil .
The values of Lift coefficients are within the bounds of 10% error compared to the experimental values . However , the values of drag coefficient I am getting have an error of above 20% compared to experimental values . I am using SA turbulence model . If the above discrepancy is due to the wake region/flow separation and wing tip vertices . How can I accurately capture these phenomena ? |
February 5, 2019, 09:55 |
AGN
Rep Power: 15 |
For airfoil major contributor of drag is skin friction drag if you are dealing with sub-sonic flows. To get accurate result make sure you are using NS-equation. Quality of the grid should be good to get an accurate result and you should resolve the boundary layer especially laminar sub-layer to get accurate drag value. For grid size next to wall estimation, you can consider the following link.
http://www.pointwise.com/yplus/ Then gradually stretch to the boundary of the domain. I personally prefer SST-k-W turbulence model for drag calculations. I believe solution procedures and turbulence models have a little effect if your grid is fine and has good orthogonality, less skewness and uniformly stretched. My conclusion is: do LES if you have computational power, else do RANS with SST-k-W turbulence model and make sure you are resolving laminar sublayer. I hope you can get an accurate result if you are able to make good mesh no matter whether you are doing RANS or LES. |
February 5, 2019, 11:39 |
#3 | |
Aamir Sultan
Rep Power: 8 |
lift and drag calculation, turbulence analysis, validation data |
Low Y+ vs High Y+ CFD simulation for determining DRAG | surajp92 | Main CFD Forum | 2 | September 19, 2017 04:15 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 11:21 |
