Calculate P/V in oscillating flow
Old   February 2, 2019, 04:17
Default Calculate P/V in oscillating flow
Ameya Durve
ameyadurve is on a distinguished road
I am simulating oscillating flow in laminar regime. I want to know how to calculate the power per unit mass in the system.
In the turbulent flow regime, I would use epsilon to determine power per unit mass. For the laminar flow when the only variables available are U and p, how should I estimate Power
ameyadurve is offline   Reply With Quote
Old   February 2, 2019, 05:06
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Power is Total Energy for time unit: dE/dt
you need to compute the kinetic energy and the thermal energy to get total energy
FMDenaro is online now   Reply With Quote
Old   February 3, 2019, 01:20
Ameya Durve
Thanks Filippo,
Assuming isothermal flow - kinetic energy in laminar flow will be the root mean square of the velocity fluctuations. And this can be used to calculate P/V. Is that correct?
Old   February 3, 2019, 04:20
Thanks Filippo,
Yes. The contribution of the power due to the kinetic energy is d(rho*V^2)/dt
laminar flow, oscillating flow
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
[OpenFOAM] How to calculate mass flow rate through arbitrary rectangle plane in paraview manoj_nav ParaView 0 March 10, 2016 03:53
how to calculate drag force coefficient of cylinder in oscillating flow vhcongtltd FLUENT 10 September 25, 2014 05:59
How to calculate RPM from flow conditions Norton FLUENT 1 March 24, 2011 06:39
how to calculate the averaged mass flow along a line over time ? iampolaris OpenFOAM Post-Processing 0 March 10, 2011 23:03
