3-D atmospheric chemical species transport and reaction
Old   January 31, 2019, 16:38
Question 3-D atmospheric chemical species transport and reaction
Adam Erickson
adam.erickson is on a distinguished road
I have a problem where there are chemical flux measurements at points within a closed chamber and the airflow rate in and out of the chamber is known. The point measurement time-series are located along a fixed plane, so in 2-D. I am wondering how I can construct a 3-D CFD simulation from these point measurements over time, given that the reaction rates and chamber dimensions are known, and what an appropriate model might be? Primarily, I am hoping to use OpenFOAM or SU2 software, since they are open-source.
adam.erickson is offline   Reply With Quote
Old   February 1, 2019, 11:23
Lucky
It's hard to say whether it is doable or not because you haven't explained your model... So you have a chamber with an inlet and outlet. Okay. If you were only solving for airflow that is doable. But you mentioned something about reactions but didn't give any details what these reactions are like. Nuclear reactions? Quantum reactions? Magical ones? Note that magical reactions is not really a joke because in numerical-land you can make magical things happen forcibly.
Btw, if you have air flow into and out of the chamber, then it's not a closed chamber!
atmospheric, cfd, chemical, reaction, transport
Modelling species transport and implementing reaction rates res FLUENT 0 May 11, 2017 11:29
species transport model simulating chemical reaction richard ben FLUENT 9 April 10, 2013 09:57
chemical reaction and species transport mohamad3564 FLUENT 0 June 11, 2012 04:58
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
how to solve the multiphase species transport without chemical reaction manjuchem0179 Main CFD Forum 0 April 13, 2009 07:26
