non dimensionalisation eddy viscosity, mixing length and turbulent shear stress
Old   January 30, 2019, 10:20
Default non dimensionalisation eddy viscosity, mixing length and turbulent shear stress
Lmath is on a distinguished road
The velocity profile is defined as law of the wall is defined as u^+ = f(y^+), where u^+ = \frac{\bar{u}}{v^*}; y^+ = \frac{yv^*}{v} and v^*=\sqrt{\frac{\tau_w}{\rho}}.
How would one then non dimensionalize the eddy viscosity v_t and turbulent sheer stress \tau_{turb} / \rho = -\overline{u^{'}v^{'}} as a function of y^+?
Lmath is offline   Reply With Quote
Old   January 30, 2019, 10:23
Lucky
You can non-dimensionalize anything anyway you want. The question is what you are going to do with these quantities later? Then you want to choose a non-dimensionalization that makes sense.
For example, the friction velocity isn't just a random non-dimensionalization of shear stress, but it is used because that's the characteristic velocity in the perturbatino when you do asymptotic analysis (i.e. u+ = y+ which happens only you scale u and y using u*).
Old   January 30, 2019, 10:29
I want to explicitly define these in terms of y^+. Then I want to relate each of these properties to \frac{du^+}{dy^+} after which these will be evaluated in the limit y^+>>1. Eventually I want to prove that in the overlap region the turbulent properties are independent of viscosity.
Old   January 30, 2019, 11:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Actually, the eddy viscosity function is naturally non-dimensional when is computed from a non-dimensional expression. Just use the correct velocity and pressure reference quantities to work directly in terms of u+ and Re_tau.
You can find in Sec.5 of this paper how to select the variables
https://www.researchgate.net/publica...ection_methods
FMDenaro is offline   Reply With Quote
Old   January 30, 2019, 13:22
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Typically, \nu_t = \nu f(y^+), for some function f(y^+). For example, at high y^+, it typically holds that \nu_t/\nu = 1/ky^+. In contrast, for small y^+, it typically holds that \nu_t/\nu = C{y^+}^3.
Of course, we're talking about equilibrium boundary layers here.
sbaffini is offline   Reply With Quote
eddy viscosity, turbulence, viscous flow
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Turbulent Boundary condition, viscosity ratio and length scale Bollonga FLUENT 80 February 16, 2013 13:06
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
Prandtl Mixing length Vs. Isotropic turbulent Mohammad Kermani Main CFD Forum 0 March 24, 2000 00:06
