Heat transfer software
Old   January 29, 2019, 12:20
crinoid
crinoid is on a distinguished road
Hi to everybody, this is my first post here (if this isn't the right place, please tell me).
I've been asked to model a heat exchanger integrated in an axial fan casing. I wonder which software I could use for that. I have used Fluent for aerodynamics (not heat exchange) and I wanted to know if it's ok for my needings. I've also seen that there are many others (Comsol, Theseus-fe, QuickField...) Has anyone used them and can tell me if they are good for what I want? Aerodynamic losses of the fan should be studied too (if the same software can do it, it would be perfect).
I should model the behavior in case of a nearby fire, so I guess the radiation component shouldn't be negligible. Ambient humidity is another factor of study.
I should model the behavior in case of a nearby fire, so I guess the radiation component shouldn't be negligible. I would be a non steady simulation.
Thank you very much for your attention
Last edited by wyldckat; February 3, 2019 at 17:47. Reason: merged posts that were identical
crinoid is offline   Reply With Quote
Old   January 30, 2019, 11:30
Lucky
Fluent works. yes.
Old   January 31, 2019, 08:19
crinoid
Thanks for your answer, I'm relieved to hear that.
Old   February 27, 2019, 11:35
vektor
vek123 is on a distinguished road
i worked with both Fluent and COMSOL, they are it robust tools, but i would suggest you to use COMSOL, because it is much convenient and really easy to use, you can do a lot without having to write udfs, the post processing in comsol is way better than everything i've seen, the only drawback is that there is no free license for students, i got mine from the university hpc, but it was limited to only heat transfer ac/dc and fluid flow.
vek123 is offline   Reply With Quote
comsol, fluent, heat, heat transfer, software
Particle Tracking - Heat transfer and temperature mxodio CFX 8 August 7, 2015 13:43
Radiation heat transfer boundary condition natrask OpenFOAM Programming & Development 0 February 8, 2015 10:05
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 18, 2014 00:45
Radiation interface hinca CFX 15 January 26, 2014 18:11
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
