BiCGSTAB Problem
Old   January 27, 2019, 04:39
Default BiCGSTAB Problem
Ashish
arotester is on a distinguished road
I have implemented BiCGSTAB without any preconditioning and it works fine with the simple unsteady diffusion equation but when I use it to solve the pressure correction equation in NS(semi-Explicit formulation) equ. it shows the alpha and omega values in O(500) which is not correct and the solution diverges. I am trying a test case as a simple 2D channel flow.
I have already tested the flow through the channel with GSSOR solver and it is working well but as soon as I replace GSSOR with the BiCGSTAB the solution diverges.
I am not able to debug the issue, can anyone please give any insights? the code is as follows,
// 		-------------------------------------Pressure Correction calculations--------------------------------------
	for(i=1;i<=nx;i++)
			pc[i][ny+1]=pc[i][ny];
			pc[i][0]=pc[i][1];
	for(j=1;j<=ny;j++)
			pc[0][j]=pc[1][j];
			pc[nx+1][j]=-pc[nx][j];
	                                ap=dt*(2.0*dy/dx+2.0*dx/dy);
					aw=-dt*dy/dx;
					ae=aw;
					as=-dt*dx/dy;
					an=as;
	alp_num=0.0;
	for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				Res[i][j]=t0[i][j]-(ap*t[i][j]+aw*t[i-1][j]+ae*t[i+1][j]+an*t[i][j+1]+as*t[i][j-1]);
				direc[i][j]=Res[i][j];
				Res_star[i][j]=Res[i][j];
				alp_num=alp_num+Res[i][j]*Res_star[i][j];
//    Next iterations
do
// Matrix multiplication [A]*[Res_0*] for alp_denominator
alp_den=0.0;
	for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				if(i==1 && j==1) // SW
					AP[i][j]=ap*direc[i][j]+ae*direc[i+1][j]+an*direc[i][j+1];
				if(i==nx && j==1) // SE
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+an*direc[i][j+1];
				if(i==nx && j==ny) // NE
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+as*direc[i][j-1];
				if(i==1 && j==ny) // NW
					AP[i][j]=ap*direc[i][j]+ae*direc[i+1][j]+as*direc[i][j-1];
				if(i==1 && (j>1 && j<ny)) //West
					AP[i][j]=ap*direc[i][j]+ae*direc[i+1][j]+an*direc[i][j+1]+as*direc[i][j-1];
				if(i==nx && (j>1 && j<ny)) //East
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+an*direc[i][j+1]+as*direc[i][j-1];
				if(j==1 && (i>1 && i<nx)) //South
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+ae*direc[i+1][j]+an*direc[i][j+1];
				if(j==ny && (i>1 && i<nx)) //North
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+ae*direc[i+1][j]+as*direc[i][j-1];
				if((1<i<nx) && (1<j<ny)) //Interior
					AP[i][j]=ap*direc[i][j]+aw*direc[i-1][j]+ae*direc[i+1][j]+as*direc[i][j-1]+an*direc[i][j+1];
				alp_den=alp_den+Res_star[i][j]*AP[i][j];
// Finding alpha
Relaxation=alp_num/alp_den;
// Shadow element 2 calculation
for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				shad2[i][j]=Res[i][j]-Relaxation*AP[i][j];	// Updated pressure correction value
// Matrix multiplication [A]*[s] for alp_denominator
om_num=0.0;
om_den=0.0;
	for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
					APshad[i][j]=ap*(shad2[i][j])+ae*(shad2[i+1][j])+an*(shad2[i][j+1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+an*(shad2[i][j+1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+as*(shad2[i][j-1]);
					APshad[i][j]=ap*(shad2[i][j])+ae*(shad2[i+1][j])+as*(shad2[i][j-1]);
					APshad[i][j]=ap*(shad2[i][j])+ae*(shad2[i+1][j])+an*(shad2[i][j+1])+as*(shad2[i][j-1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+an*(shad2[i][j+1])+as*(shad2[i][j-1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+ae*(shad2[i+1][j])+an*(shad2[i][j+1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+ae*(shad2[i+1][j])+as*(shad2[i][j-1]);
					APshad[i][j]=ap*(shad2[i][j])+aw*(shad2[i-1][j])+ae*(shad2[i+1][j])+as*(shad2[i][j-1])+an*(shad2[i][j+1]);
				om_num=om_num+APshad[i][j]*shad2[i][j];
				om_den=om_den+APshad[i][j]*APshad[i][j];
//Calculating omega
omega=om_num/om_den;
for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				pc[i][j]=pc[i][j]+Relaxation*direc[i][j]+omega*(shad2[i][j]);	// Updated pressure correction value
				Res[i][j]=shad2[i][j]-omega*APshad[i][j];	// New Residue
b_den=alp_num;
alp_num=0.0;
for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				alp_num=alp_num+Res[i][j]*Res_star[i][j];		// updated value for next iteration
direc_fac=(alp_num/b_den)*(Relaxation/omega);
for(i=1;i<=nx;i++)
		for(j=1;j<=ny;j++)
				direc[i][j]=Res[i][j]+direc_fac*(direc[i][j]-omega*AP[i][j]);	// updated value for the next iteration
gRMS=sqrt(fabs(alp_num/(nx*ny)));
gcount++;
//if(gcount%3000==0)
printf("gRMS=%f\t\tgcount=%d\talp=%f\n",gRMS,gcount,Relaxation);
time=time+dt;
}while(gRMS>0.000001);
Regards,
Ashish
arotester is offline   Reply With Quote
Old   January 27, 2019, 05:05
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
What about the BCs. for the pressure equation?
FMDenaro is online now   Reply With Quote
Old   January 27, 2019, 05:09
Ashish
I have given homogenous Neumann at the inlet and the walls whereas the Dirichlet(zero) at the outlet.
Old   January 27, 2019, 07:12
Ashish
Update:
I fixed the reference pressure near the outlet close to zero and applied the homogenous Neumann at all boundaries. This gave the correct answer with GSSOR, CGS and BiCGSTAB but the values of alpha and omega seem to be in the order of 200 to 300 which I believe is not correct.
Can someone please give an answer to this problem that why it is giving such a high value (it was showing such high values even before)?
Regards,
Ashish
Old   January 28, 2019, 09:29
Question
Ashish
Does anyone have any feedback on the code????
Old   January 28, 2019, 16:07
AliE is on a distinguished road
Hi, unfortunately I have no time to check you code but honestly speaking... Do you really need to do your own BiCGSTAB? Moreover a preconditioner is essential to speed up the calculations!
There are several libraries that you can you "just" to solve a linear system. For example, I use PETSc which is simple and efficient. If you look online maybe you can find even something easier. In this case you will forget every detail related to the linear solver and you wil have more focus on your own code. Think about it
AliE is offline   Reply With Quote
Old   January 29, 2019, 01:31
Ashish
Thank you for the suggestion.
I will take a look at PETSc and its packages.
You are right that I can focus more on my own code if I use the solver packages but I have already written the code and it's working but there are some bugs in it. It will take me some time to debug the code and same time will be taken to learn to adopt PETSc.
So, debugging this code will be a priority and I am still trying for it.
Thank you,
Regards
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
