Relation between integral time and integral length scale
Old   January 24, 2019, 12:04
Question Relation between integral time and integral length scale
Brandon
kepler123 is on a distinguished road
Hi everyone, I was wondering if any of you could help me figure this out. I basically need a relation between the integral length scale and the integral time scale, so that knowing one of them I would be able to calculate the other.
This is what I have:
Measurement of velocity at just one point, i.e.: A Time series measurement of inflow velocity on a wind turbine blade. Using this I can calculate the integral time scale using a simple two-point (in time) correlation.
Since I know the velocity through this point in time, I could calculate the mean and fluctuating velocity components.
What I need:
The integral length scale.
So, is it possible for me to use a simple relation of length = velocity*time such that I have:
Integral_length_scale = velocity*integral_time_scale
If this does work, what would I have to use as the velocity? Would I have to use the mean inflow velocity, the RMS or something else?
P.S: I do remember seeing a relation somewhere a few months ago when I first got into turbulence, etc. It does make sense that the relation also has something to do with the Reynolds number. I know for certain it's no direct relation as it's a flow based phenomena and some parameter such as the Reynolds number plays a role in relating the two.
kepler123 is offline   Reply With Quote
Old   January 24, 2019, 14:09
Lucky
This paper comes to mind: On the Calculation of Length Scales for Turbulent Heat Transfer Correlation
There are several methods for estimating the length scale from single point data.
Old   January 24, 2019, 14:56
Brandon
Thanks for the recommendation. It's behind a paywall and I can't even read the abstract
Old   January 25, 2019, 00:41
Lucky
You can always email the author and ask them how to do it. Emails are free.
You can calculate the power spectrum and extrapolate it to the zero frequency (example here in this NASA-TM). There are many ways you can find if you google turbulence length scale from hot wire.
Old   January 25, 2019, 05:54
Brandon
Awesome. Thanks a lot for your help, the power spectrum way seems to be something I can work with.
Old   January 25, 2019, 10:14
DJF
DJF is on a distinguished road
Assuming Taylor's hypothesis of "frozen turbulence", the length scale in streamwise direction (Lx) can be estimated from the mean velocity (U) and time scale (Tx) by following relationship:
Lx = U*Tx
DJF is offline   Reply With Quote
Old   January 25, 2019, 18:01
Brandon
Awesome, thanks!
length scale, time scale
Integral Length scale and Reynolds stress tensor ssa_cfd Main CFD Forum 3 January 10, 2019 14:12
estimation of integral time scale Clementine FLUENT 0 February 28, 2008 12:29
Integral time scale in boundary layer Christian Main CFD Forum 0 November 23, 2005 05:43
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 14:26
Calculation of lagrangian integral time scale R.Sripriya FLUENT 4 June 12, 2003 13:49
