how long does it take to have a fully turbulent flow? |
January 23, 2019, 07:27 |
Theo
Rep Power: 17 |
I simulate a flow through a squared duct, Re=2E9 (I set the kinematic viscosity to 1.46E-10 in order to have a fast transition to a turbulent flow), periodic bc in streamwise direction. Some pertubation is added initially to the flow field. The duct width is resolved by 240 grid points. The convective terms are approximated by a 5-th order scheme. No turbulence model is used, thus, I perform kind of a implicit LES. After simulation of 0.05 s I see only very small fluctuations, about 1000 times smaller than what I would expect to see in fully developed turbulence. My question is: after which time span can I expect to see turbulent fluctuations? Do I need too simulate longer, or is it already clear that there is a problem with my simulation? Best, Holger |
January 23, 2019, 07:53 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
If I understand, you are simulating a full confined rectangular duct having only inflow/outflow periodic, right? Are you starting from the laminar solution with a perturbation? Consider also that the lateral walls requires to use a very fine grid, therefore compute the y+ of you first celle close to the walls. Then, you must use the non-dimensional numbers based on wall velocity, then the time must be non dimensional using the corresponding reference time. Compute the total kinetic energy versus the time, you should find an energy equilibrium (indicating a fully developped flow) after some dozens of non dimensional time units. At this time you can collect the samples for the statistics. |
January 23, 2019, 08:14 |
Theo
Rep Power: 17 |
yes, I have a full confined rectangular duct having only inflow/outflow periodic bc and I start from the laminar solution with a perturbation.
The grid is refined at the walls. However, due to nu=1.46E-10 m**2/s the first point is at y+=1000, and the simulation time of 0.05 s is 8E6 non-dimensional time units. I anticipate your answer might be that with y+=1000 I do not resolve the relevant processes to initiate turbulence, so I will start a simulation with a more realistic value for nu. |
January 23, 2019, 08:35 |
#4 | |
Rep Power: 73 |
yes, start first a case at low Re number in such a way that you have at least 3-4 nodes at y+<=1. |
January 23, 2019, 10:13 |
Lucky
Rep Power: 66 |
The high frequency parts develop quite fast, around 6-8 eddy turnover times which you can estimate using nu*L/U^3. After this time you should see appreciable velocity fluctuations. The large eddies of course take longer and go like the flow-thru time and it will take many many flow-thru times to establish the proper statistics for the fully developed state.
How long is 0.05 s relative to the streamwise length? Maybe you just need to run it a lot longer. y+ of 1000 is nearing the edge of the boundary layer (if this was like freestream flow over a plate). But you have flow in a channel, the y+ shouldn't be that high except the cells in the centerline. Something does not sound right if your first cell is at a y+ of 1000... But supposing it is true, you probably have an x+ and z+ of 1000 or more which is far too coarse to resolve anything. Last edited by LuckyTran; January 23, 2019 at 13:47. |
January 25, 2019, 04:43 |
Theo
Rep Power: 17 |
I started a new simulation setting nu to 1.46E-5. For this condition there are 8 grid points at y+<1. I run for 1s which corresponds to 13 flow through times or 580 non-dimensional time units based on wall quantities. However, I develop very very little fluctuations, of the order of 1E-9 m/s while the bulk flow velocity is 1.5 m/s. Btw, Re based on the duct width and the bulk velocity is 4100.
I assume now I should actually see a fully developed flow, or? |
January 25, 2019, 04:48 |
#7 | |
Rep Power: 73 |
Could you plot the total kinetic energy versus the non-dimensional time? Then, what about the profile u+(y+), it is still like a laminar profile? |
January 25, 2019, 04:53 |
Rep Power: 73 |
Just to add that a fully confined duct can produce suppression of oscillations, you could need to run for longer time than the two-periodical channel. That could depends on the ratio W/H.
Paolo (@sbaffini) could tell us more, he did some simulations for this case |
January 25, 2019, 11:28 |
#9 | ||
Lucky
Rep Power: 66 |
What's the length to height ratio? It needs to be some big integer like 5,10, 15, etc. Quote:
The square duct is quite similar to the circular pipe. |
January 25, 2019, 13:00 |
#10 |
Rep Power: 73 |
January 28, 2019, 04:58 |
#11 |
Theo
Rep Power: 17 |
Attached I plot the u(y) velocity profiles for 2 time instances and the average and max streamwise velocity over time. It is all in SI units because, to be honest, I have some trouble to establish the non-dimensional parameters:
The domain size is 2*delta x 2*delta x 8*delta and delta is 0.02, nu=1.46E-5, rho=1.2 (again, all written in SI units). So Re based on the max u velocity and delta is about 3500 which should lead to a turbulent flow. I apply a pressure gradient of dp/dx=-0.36. tau_w=-dp/dx*0.5*delta (for pipes) = 0.0036 u_tau=sqrt(tau_w/rho)= 0.055 Re_tau=u_tau*delta/nu=75 (I would expect 150 based on Re ???) now, I calculate it based on the velocity gradient obtained from the average streamwise velocity at the first grid point: du/dy=4444 tau_w=rho*nu*du/dy=0.078 u_tau=sqrt(tau_w/rho)=0.25 Re_tau=350 ??? Obviously I make some mistake. Your opinion is very appreciated. |
January 28, 2019, 07:21 |
#12 |
Rep Power: 73 |
Have you averaged the velocity profile along the streamwise direction? It appears smoothed so I suppose that is a statistical profile obtianed by the pointwise LES profiles, right?
However, I strongly suggest to work solving directly the non-dimensional equation. If you use u_tau = [Delta p*H /(rho0*Lx)]^0.5 the nondimensional equations solves directly in terms of u+ vector field and you have a forcing term in the momentum equation along x to be prescribed simply as -1 and you can set directly the value of 1/Re_tau in the diffusion parameter. More details can be found in Sec.5 here https://www.researchgate.net/publica...ection_methods |
January 28, 2019, 07:46 |
#13 |
Theo
Rep Power: 17 |
yes, I averaged in streamwise direction. But the profile is anyhow the same at each cross-section.
If I use the equation you posted (u_tau = [Delta p*H /(rho0*Lx)]^0.5) I receive Re_tau=150 as expected. But for a channel flow it should be u_tau = [Delta p*H/2 /(rho0*Lx)]^0.5, or? |
January 28, 2019, 08:07 |
#14 | |
Rep Power: 73 |
January 28, 2019, 08:11 |
#15 |
Theo
Rep Power: 17 |
I understand, that's why in the equation for u_tau there should be H/2, or? at least according to Pope: -dp/dx = tau_w/delta where delta = H/2 and u_tau=sqrt(tau_w/rho)
January 28, 2019, 08:40 |
#16 | |
Rep Power: 73 |
no matter about H or H/2, you just need to be congruent in the equations and you will see a factor 2 or 1 in the forcing term |
Fully develop turbulent flow | s-ammarlu | OpenFOAM | 0 | June 4, 2011 01:56 |
Fully develop turbulent flow | s-ammarlu | OpenFOAM | 0 | June 1, 2011 14:25 |
Reynolds and Turbulent flow | Frederic Dubinski | CFX | 5 | October 21, 2004 05:12 |
profile for fully developed turbulent duct flow | jeff | Main CFD Forum | 1 | November 14, 2001 22:35 |
fully developed turbulent flow in a pipe | Dipak | Phoenics | 3 | July 20, 2000 06:53 |
