Add a lighting gain (W/m^2) to a room
Old   January 23, 2019, 04:36
Default Add a lighting gain (W/m^2) to a room
Chris1590000 is on a distinguished road
Hi, I am modeling a simple room for HVAC flow simulation with air entering the room through an inlet at a low temperature, mixing with the internal gains inside the room such as lighting gains and solar gains, and then leaving the room through an outlet at a higher temperature.
Could you please tell me how to model the heat gain from the lights present in the room so that it can be accounted for in the simulation.
Chris1590000 is offline   Reply With Quote
heat gain, hvac, lighting gain
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
HVAC Modeling Humans in Room LilBort CFX 27 July 31, 2009 12:08
heat transfer: air in a room and water in a coil Alberto CFX 2 May 9, 2006 10:56
Contaminant Distribution in Air-con Room Jules Main CFD Forum 0 June 13, 2002 11:55
