Emil Jorgensen
Rep Power: 0 ![]() |
Hello Guys
Im working on a project with a hydrocyclone, and i want to get the velocities from different cross-sections in the hydrocyclone. Im have created a rake with points from 0-Radius. But when i get the data of the velocity from the Surface integral part, i only get one datapoint... I want data from every point on the rake? Can someone help me with that? Thanks in advance |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
What software you are using?
If you are using random number generator then keep trying until you get the desired result. ![]() |
data, rake points |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[OpenFOAM] Extract/plot data at a specified set of points | Tobia | ParaView | 0 | October 19, 2016 06:16 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
Text input commands to add data points | Kathryn | FLUENT | 0 | November 5, 2007 17:38 |
XYZ (ASCII format) data points into GAMBIT | Neil | FLUENT | 1 | August 7, 2007 09:24 |
