Rotating wall
Old   January 8, 2019, 09:44
Default Rotating wall
Dav3dum is on a distinguished road
Hello everyone!
I'm currently working on a comparison of rotating wall boundary condition vs Moving Refence Frame on an electrical machine. My question is that can anyone tell me how does the rotating wall appear in the solved equations?
Thanks in advance,
David
Dav3dum is offline   Reply With Quote
Old   January 10, 2019, 10:08
Lucky
I just want to point out that rotating wall and moving reference frame are completely independent of one another and you need to be careful you are interpreting your results correctly.
In the stationary frame with stationary walls you solve something. Now you set the wall rotating, which just means you give the wall a velocity. So the fluid next to the wall, due to no slip, instead of having velocity = 0, now has velocity same as the moving wall.
In a moving reference frame, your velocity is now completely redefined. A not-moving wall in the stationary frame now has a funny looking velocity in the moving reference frame (because your velocity has been redefined). So here you need to be careful what you mean by non-rotating vs rotating in either frame. It is a problem of semantics/English at this point.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Simple question about a Rotating Wall Maralady FLUENT 2 May 15, 2013 23:42
rotating wall enomis77 FLUENT 2 August 27, 2010 03:52
