January 11, 2019, 07:10 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
As I wrote before, I would start to model the problem first using a laminar assumption and setting that the stresses over the cylinder must substain in equilibrium the weight of the material. If you get that the required Re number exceeds the critical value for turbulence then you have to add more assumptions and start to think a time-dependent viscoelastic model |
[ANSYS Meshing] Error: "An allocaton was made with a negative.." | Alex0815 | ANSYS Meshing & Geometry | 1 | May 23, 2017 09:38 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 02:47 |
urgent problem : fluid height | ounifiras | FLOW-3D | 6 | December 9, 2013 18:17 |
A problem about density in liquid air definition | eis | CFX | 6 | October 29, 2013 11:27 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 15:20 |
