Compaq Visual Fortran 6.6, DLL and Module
Old   January 2, 2019, 04:41
Default Compaq Visual Fortran 6.6, DLL and Module
Bakhbergen Bekbauov
Bakhbergen is on a distinguished road
Dear Fortran Users,
I need to create and use dynamic-link library (DLL) for Fortran application using Compaq Visual Fortran 6.6. The following code works just fine:
PROGRAM AMAIN1
IMPLICIT NONE
REAL(8):: A,B,S
A = 1D0
B = 2D0
CALL SUBRO1(A,B,S)
PRINT*, 'S = ', S
END PROGRAM AMAIN1
SUBROUTINE SUBRO1(A,B,S)
!DEC$ ATTRIBUTES DLLEXPORT :: SUBRO1
IMPLICIT NONE
REAL(8):: A,B,S
S = A + B
RETURN
END SUBROUTINE SUBRO1
The result is correct:
S = 3.00000000000000
Press any key to continue
However, if I implement the same algorithm using the module, I get inconsistent result (i.e. zero):
PROGRAM AMAIN2
USE MODUL2
IMPLICIT NONE
A = 1D0
B = 2D0
CALL SUBRO2
PRINT*, 'S = ', S
END PROGRAM AMAIN2
MODULE MODUL2
IMPLICIT NONE
REAL(8):: A,B,S
END MODULE MODUL2
SUBROUTINE SUBRO2
!DEC$ ATTRIBUTES DLLEXPORT :: SUBRO2
USE MODUL2
IMPLICIT NONE
S = A + B
RETURN
END SUBROUTINE SUBRO2
The result is incorrect:
S = 0.000000000000000E+000
As can be seen above, DLL contains only subprogram in both cases (SUBRO1 and SUBRO2, respectively). I have built DLL and LIB files from the visual development environment. The second case (with the use of module) represents the structure of my large source-code so I need to resolve this issue. Any advice would be greatly appreciated.
Bakhbergen is offline   Reply With Quote
compaq visual fortran 6.6, dll, module
CFX11.0 cannot find dll in User Fortran brunoc CFX 0 April 4, 2007 11:42
