heat line visulization
Old   December 30, 2018, 20:56
Question heat line visulization
niaz's Avatar
A_R
niaz is on a distinguished road
Hello all
I wanna visualize heat lines in my case. is there any way to visualize it with cfd_post or fluent builtin features?
niaz is offline   Reply With Quote
Old   January 7, 2019, 13:06
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Originally Posted by niaz View Post
Hello all
Have you got the solution?
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   January 7, 2019, 13:08
niaz's Avatar
A_R
Not yet, one way is to solve the heat function inside the software but i am looking for a simple way.
Old   January 7, 2019, 15:48
Lucky
What are heat lines?
Old   February 17, 2020, 07:57
Default How to get heatlines in 3D?
vidyadhar
vidyadhar is on a distinguished road
Heat lines are similar to stream lines. If we have a heat flux vector potential then the derivatives of that potential would give heat flow lines.
I too wanted to plot heat lines. But I need help on how to do!
I have simulated three dimensional heat and fluid flow problem in Fluent. I have the data for velocity, temperature fields.
Now I want to obtain an unknown function "theta" by solving the below equation:
curl(theta) = rho*cp*(V)*T - k*(grad T)
where the terms on the right hand side (density, specific heat, velocity vector, temperature, thermal conductivity) are known from data. The left hand side contains curl of an unknown function “Theta”. I want to find this “Theta” variation which gives me heat function distribution.
Is it possible? If so, I request the procedure how it is to be done.
This "theta" is the heat flux vector potential in three Dimensions.
The reference article on this subject is "Peter Vadasz, Heat Flux Vector Potential in Convective Heat Transfer", Journal of Heat Transfer, 140(2018) 051701-1
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   February 17, 2020, 09:20
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I am not sure to understand what is theta (I have never seen such a relation) it is a vector field not a scalar function, should theta be identified as the gradient of the temperature?If it is the LHS vanishes, otherwise, if k is constant you can apply the curl to both term of the relations and write three elliptic equations for theta with the vorticity components as source terms
FMDenaro is offline   Reply With Quote
Old   July 17, 2020, 13:38
damu
damu1414 is on a distinguished road
Dear all,
Thank you for the thread.
I would like to know if anybody has tried plotting heatlines using tecplot. There is an option to find the heatfunction components and plot the same similar to streamfunction.
Thank you
damu1414 is offline   Reply With Quote
cfd_post, fluent, heatlines
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
