Method of calculating Sutherlands equation for Cesium vapor?
Old   December 29, 2018, 16:29
Default Method of calculating Sutherlands equation for Cesium vapor?
Andrew Somorjai
massive_turbulence is on a distinguished road
What I want to ask is just a general idea of how to go about calculating Sutherlands equation given that I don't have Sutherland coefficient As and Sutherland temperature Ts for Cesium vapor.
I looked at this page for the transport model
https://cfd.direct/openfoam/user-gui...hermophysical/
and this page also
https://www.lmnoeng.com/Flow/GasViscosity.php
and this
https://www.cfd-online.com/Wiki/Sutherland%27s_law
Basically I needed this for OpenFOAM buoyantPimpleFoam. I already have the Janaf table for Cs.
Thanks!
massive_turbulence is offline   Reply With Quote
Old   December 31, 2018, 20:18
Andrew Somorjai
I extrapolated the values from ammonia and several other known gases and it turns out cesium vapor is almost on the same curve as ammonia. I attached the chart.
For ammonia the Sutherland Temp = 293.15K and Constant = 370K and reference viscosity is 9.82 uPa*s.
cesium vapor, poise, sutherland transport
Calculating Velocity from a VLM method jd88 Main CFD Forum 0 September 9, 2010 17:24
just calculating the energy equation peterle CFX 2 April 21, 2010 23:32
calculating Normal vector in level set method amir2920 Main CFD Forum 1 July 21, 2009 08:25
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
calculating missle configuration by panel method Daniel Main CFD Forum 5 January 6, 2003 09:09
