December 27, 2018, 10:37 |
Grid generation policy for a multiphase flow in huge dimensions
Sadegh
Rep Power: 11 |
Hi every one
I want to study a multiphase flow (water+ metallic particles (Ca)) which enters a lake with huge dimensions (4km*2km*2m). The target is specifying the dispersion and sedimentation of metallic particles inside water. It's worth to mention that the lake doesn't have any output (channel, soil diffusion, and etc.) except water vaporization from its interface with the surrounding air. I uploaded a simple drawing of the problem. http://s8.picofile.com/file/8347065284/Drawing1.jpg Could anyone guide me through grid generation/independency + model validation policy? I thought about two ways till now: 1- Generation the mesh at its original dimensions plus, using some solution like using size function or link meshes in order to decrease and control mesh volume. 2- Performing grid independency and validation of the model at lower scales based on a solved numerical or experimental model then using scale factors (in fluent) to reach the real dimensions. I'm using Gambit 6.2.4 and ANSYS Fluent 19.2 through this problem. Any help will be appreciated. Thanks. Last edited by Sadegh.A; December 28, 2018 at 16:28. Reason: modification of the title and context |
grid dependency, huge model, multiphase flow, validation data |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 01:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
BC problem with Eulerian-Eulerian Multiphase Flow | ngoc_tran_bao | CFX | 4 | September 24, 2016 05:43 |
