Boussinesq assumption
Old   December 17, 2018, 10:04
Default Boussinesq assumption
Mehdi Babamehdi
mb.pejvak is on a distinguished road
In Boussinesq assumption we consider the term derived from convective term and consider it as a diffusion term?
mb.pejvak is offline   Reply With Quote
Old   December 17, 2018, 10:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Are you talking about the turbulence model in the momentum? In such case yes, the unresolved non linear term coming from the convection is converted in a non linear diffusive term
FMDenaro is offline   Reply With Quote
Old   December 17, 2018, 11:14
Mehdi Babamehdi
Yeah, I am talking about turbulence model in momentum. The question is how we can interpret it. and is there any phenomena in turbulence which convert the convective term into diffusive term or this is only a mathematical assumption.
Old   December 17, 2018, 11:17
Lucky
At the Kolmogorov scales of turbulence, that is exactly what happens.
Old   December 17, 2018, 11:32
That is a model of a macroscopic observation that the turbulence increases the mixing of a specie. In analogy, this old model convert the fluctuations in an averaged increasing of diffusion of the momentum. However, that is not correct over all the range of scale since the energy transfer has an inertial range at sufficiently high Re number. Furthermore, turbulence can be onset from the convective term, therefore you can idealize also the energy cascade in an inviscid flow. As a consequence, the model will introduce a different mathematical character.
boussinesq assumption
Chtmultiregionfoam with boussinesq assumption solver developed...needs suggestions an manuc OpenFOAM Programming & Development 8 December 30, 2016 03:08
Modelling conjugate heat transfer with boussinesq assumption manuc OpenFOAM Programming & Development 0 December 24, 2016 04:48
Chtmultiregionfoam with boussinesq assumption : hanging pointer when running testcase manuc OpenFOAM Programming & Development 0 October 31, 2016 05:46
Boussinesq eddy viscosity assumption siw Main CFD Forum 2 February 17, 2011 13:30
Boussinesq Assumption tstorm FLUENT 3 October 26, 2009 06:11
