December 16, 2018, 12:18 |
Vortex Panel Method
Rafaelle
Rep Power: 8 |
Hi
I successfully implemented the source panel method over the last few weeks but I have trouble implementing the "constant vortex panel method" (no sources, only vortices, with constant strength over one panel). The problem is that the calculations seem to be similar to the source panel method but computing the derivative of theta with regards to the normal of the surface is a real trouble. Unfortunately, I don't find a lot of papers with the constant vortex panel method; do you have some in mind? Sincerely PS : A lot of people use the source + vortex panel method or the second order vortex panel method; I would like to use the constant vortex panel method without sources first even if it's not optimal so that I can compare the different methods. |
December 17, 2018, 11:16 |
Rafaelle
Rep Power: 8 |
Help me please!
Really lost! Vortex Panel Method | reynolds_master | Main CFD Forum | 0 | December 13, 2014 07:00 |
help 3D panel method | luca | Main CFD Forum | 0 | June 22, 2004 05:16 |
Panel method problem | niavarani | Main CFD Forum | 1 | June 17, 2003 11:01 |
calculating missle configuration by panel method | Daniel | Main CFD Forum | 5 | January 6, 2003 09:09 |
panel method | Waleed Mohamed | Main CFD Forum | 2 | March 30, 1999 22:26 |
