December 13, 2018, 07:08 |
UDf and divergence
Doğukan Arslan
I have an analysis which is laminar, 3D, conjugate heat transfer and related to udf. I set inlet velocity and temperature ,and heat flux fr wall bottom. Without udf code, the analysis can be converge but while i am using udf the analysis was divergence. By the way, my udf code is valid because in previous cases, this code was used and it worked.
I have four different mesh for one model. Model which have the finnest cant be converged but other ones which have more coarse mesh can be easily converged. |
conjugate heat transfer, laminar flow, udf |
UDF srivastava and sundaresan friction model - divergence of the solutor | Luca_Panariello | Fluent Multiphase | 1 | January 18, 2017 10:07 |
Viscous dissipation UDF for multiphase DDPM (Divergence problem) | bhargavbharathan | FLUENT | 0 | November 30, 2016 12:23 |
Divergence in non-Newtonian fluid UDF | moabdi | FLUENT | 0 | June 23, 2016 11:30 |
Divergence with source UDF for VOF | aleni32 | Fluent UDF and Scheme Programming | 4 | December 28, 2014 01:16 |
UDF divergence of a vector | cris | FLUENT | 3 | September 4, 2014 18:06 |
