gas combustion test case
Old   May 16, 2000, 07:15
Default gas combustion test case
Tomasx Ochrymiuk
Hello, I need information, where can I find some (standard) test case in subject natural gas combustion (mayby some experimental gas turbine chamber or burner). I need geometry, boundary conditions and experimental results. I'm making Phd thesis and I'm going to validate numerical cod.
Thanks
Tomesz Ochrymiuk
Old   May 18, 2000, 05:24
Default Re: gas combustion test case
Nuray Kayakol
Please read N. Kayakol, N, Selçuk, I. Campbell and Ö. Gülder, Performance of Discrete Ordinate Method in a Gas Turbine Combustor Simulator, Experimental Thermal and Fluid Science, 21, 134-141 (2000).
fuel is propane not natural gas. But it may help to verify the code expecially for radiative heat transfer calculation. Definition of boundary conditions significantly affects the result. I will send it to you as pdf format.
Dr. Nuray kayakol Sisecam glass research center
Old   June 20, 2000, 03:42
AYYAPILLAI MURALI
Dear Dr. Nuray kayakol,
I would be grateful if you could send the pdf document on the gas combustion test cases as I have been working on a similar problem.
Thanking You
Ayyapillai Murali
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
looking for a test case, DES, Supersonic flow kaarthik Main CFD Forum 0 June 7, 2007 06:49
Test case data Snegan Main CFD Forum 3 June 14, 2006 09:56
jet stream test case Vincent FLUENT 0 July 9, 2002 05:45
Phoenics 3.4 Test Case - Combustion & Immersol Sam Matson Phoenics 2 May 1, 2002 10:29
