Euler-Euler modeling of non-newtonian fluid in which software ?? |
December 8, 2018, 08:16 |
navid
Rep Power: 8 |
Hi everybody
I am trying to simulate a non-newtonian fluid which transfers solid particles by COMSOL and I have several problems. First of all, it is not prepared in COMSOL to select non-newtonian fluid in Euler-Euler model. Second, my geometry is two 3D concentric cylinder which only the interior one rotates. In Euler model the option for wall movement disappears ! Now if you are familiar with Comsol or you have experience in such a simulation in other softwares ,would you please help me to solve it or do you advise to change my software? |
December 10, 2018, 09:54 |
Cees Haringa
Well, you might have to write your own code for that...
There is software that can do it, in principle. For example ANSYS FLUENT. But you are unlikely to get sensible results. In brief, bubbles will lead to accelerations (strain) at small scales (in their wake for example), which will modify your local viscosity on a scale much smaller than your grid. Non-newtonian viscosity models implemented in software such as FLUENT do not account for these small-scale strains, that may have a big impact on your rheology. Instead, it uses the strain-rates of the resolved scale, which are not representative and hence will lead to poor estimations of the true rheological behavior, and consequentially, multiphase interactions. The same applies for turbulence in non-newtonian flows, hence FLUENT has also disabled the use of non-newtonian rheology together with turbulence (the user can re-enable it, at own risk). Apparently COMSOL chose to disable the combination of rheology and eulerian multiphase, since the models are not designed to work together and hence are highly likely giving garbage results if forced to. A lot of developments are still required to include the effects of unresolved strains originating from gas-liquid interaction and turbulence on rheology. For turbulence, some steps are being made (such as Garilov et al. 2014, turbulence model for power law fluids), but Eulerian multiphase + rheology (or better, multiphase + turbulence + rheology) is a highly unexplored field. If you are going to dive into it, do so carefully. |
December 10, 2018, 16:58 |
navid
Rep Power: 8 |
Thank you very much.
That was helpful. |
comsol, non-newtonian fluid, rotating |
Modeling Solid and Fluid at the same using Interface BC..Help needed | Prince Jassal | Main CFD Forum | 1 | June 12, 2013 06:07 |
Solid Fluid interactions with non newtonian fluid | daniebae | ANSYS | 12 | May 27, 2013 04:57 |
Is 2-way FSI valve modeling with seperate fluid domains possible? | Maurosso | FLUENT | 4 | March 7, 2013 09:56 |
Modeling heat transfer fluid to solid | Elvis1991 | FLUENT | 6 | December 7, 2012 10:08 |
fluid dynamics software sought for 3D models | Woon San Joe | Main CFD Forum | 1 | March 12, 2004 00:00 |
