December 4, 2018, 07:32 |
friction factor vs Reynolds number
Rep Power: 8 |
I want to compare my numerical result of friction factor vs Reynolds number for Plane Poiseuille flow with analytical result. but I found the Moody diagram for pipe flow but not any data about the channel flow. Please anyone can share any link, book or paper containing this? Thank you!
December 4, 2018, 09:31 |
Rep Power: 8 |
The first part of your question is trivial, in the sense that if you know the analytical expression for the velocity, than you can readly produce the plot by your self. As you know, this make sense until the flow is laminar. For turbulent flows in plane channels you have a data base and a paper (Direct numerical simulation of turbulent channel flow up to Reτ=590 by Moser et. and the classical paper of Kim), but the data limit to 3 or 4 Re_tau. In any case you will have more references inside those papers. |
December 4, 2018, 09:48 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
DNS for such problem is now extended to Re_tau = 2000. However, the solution is for the time-evolving BL, not for the spatially evolving. I don't know if the original question is about the function cf(Re_x). |
December 4, 2018, 10:01 |
Rep Power: 8 |
Wow Re_tau 2000 looks tasty Yes natually if the plot requested is cf(Re_x), it is another story, but as soon I have understood from the question, he would like to do a "Moody chart" for the plain poiseuille.
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
