December 4, 2018, 06:02 |
Which model to use?
Federico Carotenuto
Dear all,
I would like to simulate the following case: - 2D transport of a scalar with turbulence - Part of the domain contains elements that are sinks for the given scalar (i.e.: they absorb a given quantity of the scalar, generating a negative flux in # mmol m-2 s-1). - I would like to impose velocity, pressure and turbulence quantities across the domain at every time step (i.e.: the model should only "worry" about transporting the scalar, with a fixed concentration profile at the inlet, to the outlet) I was looking at OpenFOAM, which is open-source and has a way to simulate turbulence and scalar transport...but I do not understand if it's possible to set a sink for the tracer (maybe as a boundary condition?). Any suggestion would be welcome! |
December 4, 2018, 10:35 |
Rep Power: 9 |
yes openFOAM could be helpful, it offeres several RANS/URANS models that may fit your needs. However keep in mind that if your source terms and boundary condition are too specific, it is possible that you have to implement them by yourself using codestream. If you are not experinced in CFD, than this might create you some troubles In any case you can check the available bcs and source terms (called fvOptions in OF) with a fast google search. |
December 4, 2018, 10:45 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
I don't know what is your goal but if you are simply considering a passive tracer having the motion governed by the lagrangian tracking, it is simply unphysical the simulation on a 2d turbulent field as it represents only a statistical solution. |
December 5, 2018, 11:47 |
Lucky
Rep Power: 66 |
The sink can be done using a fvOptions file. Or you can directly code it into the solver. Either way you have to do some coding.
sink, source, tracer, transport model |
kklOmega omega boundary condition at the wall - OF3.0 | Artur | OpenFOAM Running, Solving & CFD | 1 | June 17, 2016 16:42 |
Turbulence model choice | dave13 | CFX | 3 | December 22, 2015 08:12 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 08:53 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
