November 21, 2018, 17:33 |
LBM units
Med oumza
Rep Power: 11 |
Dear everyone;
I am using the LBM as a CFD approach for simulating the nanofluids behaviour. My question is about the lattice units to use in the method, i.e, how to convert the physical units to the lattice ones? Let me explain more my require. To simulate a nanofluid flow using LBM one must set the the nanofluid (water+nanoparticles, exp. water+Cu) parameters by setting those of solid particles Cu) and Base fluid (water). So, my problem is how to set the lattices values of nanofluid? For example : rho_nf= (1.0-phi)*rho_f+phi*rho_p % density of nanofluid (nf), \phi is the % of nanoparticles(p) My first question: If I fix the fluid density rho_f=1, i.e the conversion factor equal their real value, how I can set the particle density? both densities have the same conversion factor? Same question for beta_nf=((1.0-phi)*rho_f*beta_f+phi*rho_p*beta_p)/rho_nf % \beta isthe thermal expansion coefficient Cp_nf=((1.0-phi)*(rho_f*Cp_f)+phi*(rho_p*Cp_p))/rho_nf % Cp is the specific heat My second question: How I can obtain the conversion factor for Cp, K(Thermal conductivity) and \beta and others Thank you in advance for your help Yours sincerely |
lbm, nanofluid, units |
Thermophysical Property Units | johanz | OpenFOAM Pre-Processing | 2 | December 16, 2018 11:08 |
Lattice Boltzmann (LBM) Based Drag Models proposed after Beetstra(2007)? | ronithstanly | Main CFD Forum | 1 | May 29, 2018 08:43 |
Practical difference between FVM and LBM? | pharg_yrartibra | Main CFD Forum | 2 | November 25, 2013 11:52 |
units in OpenFOAM | megacrout | OpenFOAM | 4 | July 19, 2011 09:04 |
units of geometrical parameters lost | SoobY | ANSYS Meshing & Geometry | 2 | January 10, 2011 04:58 |
