November 16, 2018, 05:46 |
Which CFD Software
Stefan
Rep Power: 10 |
Hallo guys,
we are a company who produces high pressure valves for the production of polyethylene and urea Industry. The pressure drop ranges from 400 bar to 6 bar outlet to as high as 2000 to 3000 bar on the inlet versus 300 bar on the outlet. So we have pretty high pressure drops with a custom defined user material. We need to analyse the flow of polyethylene (polyethylene density and viscosity is described with a formula depending on pressure and temperature). Im the person who can decide which cfd package since actual (AVL Fire M). What solution would fit our needs most? Maybe later on we want to analyse the flow induced vibrations etc.... My favourite is Ansys since it seems to be most robust and robustness is important for me since we always have problems due to the high pressure drop simulation (up to 1600 bar pressure drop makes it always possible to get converge result with RANS general) Best regards, Stefan |
November 16, 2018, 06:06 |
Additional
Stefan
Rep Power: 10 |
As when i see the number of viewers i may think that ansys is the best solution overall because it seems to be that it is the most used solution. But we do have very special requirements due to the very high pressure drop and the kind of medium we use.
And what i know already: OpenFoam is not able to handle our problem according to the answer of a company who provides an open foam based solver. Since we are using ABAQUS we may use X Flow because it is from the same company but im not sure if x flow can handle the problem..... But there seems to be a coupling environment from frauenhofer institut to make FSI between Ansys CFD and FEM Abaqus |
November 16, 2018, 09:16 |
Martin Novák
Rep Power: 13 |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 18:09 |
Applicability of a specific software in CFD modelling | ivan-s | Main CFD Forum | 0 | April 22, 2014 14:30 |
What is the optimal (economically and user friendly) CFD software for my application? | Rame | Main CFD Forum | 0 | August 10, 2009 06:30 |
ASME CFD Symposium - Call for Papers | Chris Kleijn | Main CFD Forum | 0 | September 25, 2001 11:17 |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 07:41 |
