Pressure loss over a valve
Old   November 11, 2018, 10:54
Default Pressure loss over a valve
Angelina
Unicorn91 is on a distinguished road
I tried to calculate the mass flow over a valve. First made a calculation by hand with Bernoulli:
(See image "Bernoulli.png")
Okay that was easy. Now I want to insert e pressure loss because of the valve geometry. In Literature it ist described this way:
(See image "Druckverlustbeiwert.png")
But now if zeta is < 1 my volume flow (bzw. mass flow) grows.
Is that possible?
Pipe contractions can have e zeta term of 0.5. Would that rise the mass flow?
In which situations is that possible?
Thanks for your help!
Unicorn91 is offline   Reply With Quote
Old   November 11, 2018, 13:10
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
As you know, Bernoulli cannot be applied when a dissipative process is acting, as happens for the viscous flow around a valve. Correction due to friction that casues pressure loss can be found in fluid mechanics textbooks, such as White. You find many exercises
FMDenaro is offline   Reply With Quote
Old   November 11, 2018, 17:49
Cool
Angelina
I was a bit confused as I realized that the definition of the pressure loss is based on Bernoulli as I described above.
https://de.wikipedia.org/wiki/Druckverlustbeiwert
First I startetd with the "first law of thermodynamics":
(See "first law of thermodynamics.png")
In my opinion I have to respect the pressure loss separately as I described. But I was not sure when I saw the definition of the pressure loss. And what happens when zeta is < 1?
@ FMDenaro: I've found the testbook from White. Wow almost 900 pages! Can you tell me which chapter or which exercise you mean?
Old   November 11, 2018, 18:11
Bernoulli requires the flow to be incompressible and the absence of any dissipation of energy due to viscosity and conducibility. This way the total pressure is invariant. Thus, you can compute the difference between the total pressure and the static pressure.
On the other hand, consider the example of the exact viscous solution in a channel (Poiseuille). You will find the pressure difference between two locations along the streamwise direction. This "pressure loss" is due to the friction.
In your case the flow around a valve produces separation due to viscous effect.The flow is not isentropic and the total pressure changes along the streamwise direction.
Search Bernoulli in the White textbook and compare to the section of viscous flows.
Old   November 12, 2018, 05:00
Joern Beilke
JBeilke is on a distinguished road
There you find the bernoulli equation with pressure loss.
JBeilke is offline   Reply With Quote
Old   November 12, 2018, 05:44
Yes, the correction in the Bernoulli integral due to the viscous action highlights that the total pressure is no longer invariant in a non-isoentropic flow.
Old   November 14, 2018, 17:20
Angelina
Okay I forgot to say, in my situation I have a turbulent flow (RE = 10'000).
I tried an example from the textbook "White" for viscouse flow: see "Example Viscouse Flow Turbulent".
The resulting velocity (and massflow) is much too high.
So I think the main input of the pressure loss comes from the valve orifice.
@JBeilke: Right, that's how I calculated my second equation (see "first law of thermodynamics.png") So I think thats the right way.
But I was a bit confused about the definition of the flow coefficient Kv (see "Kv-Wert"). The flow coefficient is normaly given, when you buy a valve.
Maybe this is a simplification?
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Negative Total Pressure Loss Coefficient near the casing in axial compressor mitra22 CFX 1 December 15, 2017 23:34
High Pressure Let Down valve soletto Main CFD Forum 0 December 20, 2016 17:08
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
