How to deal with Gravity using SIMPLE approach |
October 11, 2018, 15:24 |
Hi all,
I'm trying to have a steady-state stoke code using FVM staggered grid in 2D, with incompressibility and without inertia. So a quite reduced problem. The only "fancy" thing that is mandatory in my problem is having a gravity source term. From what I can understand of the SIMPLE approach, you first guess P, then solve u,v, then calculate p' using mass conservation and update u,v using p' and u',v'. In my code, I create two loops: one outer loop for momentum eqs. and one inner loop dealing with p' and u,v corrections. When I only iterate the inner loop, I have, what I think is a good result, though once I use that solution to iterate the outer loop my solutions becomes totally wrong, and my overall pressure increases by a factor of 100-1000... I cannot understand how to fix it, but I am pretty sure it is coming from the gravity term which makes the things complicated... The matlab test code is attached, hope you can help me! I am getting very frustrated about it. Thank you! Last edited by Nico42; October 11, 2018 at 15:26. Reason: Typo |
October 12, 2018, 16:27 |
Rep Power: 14 |
Dear Nico42,
add your gravity source explicitly after or before your simple approach. There should'nt be any special treatment. Regards |
October 12, 2018, 19:13 |
Dear Eifoehn4,
Thank you for your answer! However, I don't quite get it. How can I treat the gravity forces after using the SIMPLE algorithm? It should be part of the formulation to have correction pressure no? In the model I am trying to make, I want buoyancy to drive the flow. This in order to model, for instance, a heavy viscous ball sinking inside a less dense viscous field, or a light ball ascending through that same viscous field. Therefore we get a pressure within the model that depends on the weight of the material (rho*g*h) and we get a stoke pressure which depends on the flow triggered by the density contrast between the ball and the viscous medium. The problem I am having right now is to get a correct pressure solution, as it seems that when I treat the body forces outside the pressure term it does not work between outer iterations. Thank you again for your answer, I hope my problem is now clearer Nico |
simpleFoam with gravity, based on interFoam | JonW | OpenFOAM | 1 | May 9, 2019 11:08 |
Time-varying gravity in interFoam | gradylemoine | OpenFOAM Programming & Development | 2 | October 8, 2013 12:53 |
UDF fails to model 9.81m/s^2 gravity | jpo | Fluent UDF and Scheme Programming | 2 | January 24, 2012 19:15 |
how to consider gravity in CFX | shrimp | CFX | 4 | September 8, 2008 21:41 |
Help: gravity in CFX | Dejun Jing | CFX | 2 | July 22, 2002 09:58 |
