steady free-surface flow simulation interFoam
Old   October 8, 2018, 11:21
Default steady free-surface flow simulation interFoam
Kahlil Fredrick Cui
cuikahlil is on a distinguished road
Hello!
Is it possible to simulate a steady free surface flow in interfoam?
The scenario I want to simulate is similar to a gravity-driven fluid flow down an inclined plane, but I only want to model a segment of it where the flow velocity is steady. Could this be done through correct BCs perhaps?
I have tried modifying the interfoam code to accommodate cyclic boundaries while being inclined but the velocities quickly rise non-stop (calculated velocities can reach up to 100 m/s for 26 degrees and will continue to increase unless terminated) and abnormally high velocities are observed at the air-water interface.
I gladly welcome any ideas. Thank you in advance!
cuikahlil is offline   Reply With Quote
cyclic boundaries, gravity flow, interfoam
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
free surface simulation Pit7512 CFX 12 October 23, 2015 12:07
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 09:54
Steady flow in steady and unstedy simulation Kwiaci FLUENT 4 August 29, 2012 13:46
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
