worst result with morre points
Old   May 2, 2000, 13:30
Default worst result with morre points
Sébastien Rouvreau
Hi, My current problem is that my 3d code gives a worst result with a grid 100*100*50 big than with a grid 100*50*50 big for exctly the same problem (laminar flow around a cube)
Any suggestions, comments or explanations would be welcome
Old   May 2, 2000, 14:26
Default Re: worst result with morre points
John C. Chien
(1). Re=1.o? Re=10.0? (2). Mesh arrangement between the two? (2). Plot results vs mesh size, and try to reach the mesh independent solution. (3). Two points can not extablish the trend. good luck.
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 04:13
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 24, 2012 00:41
Gauss Quadrature points dhruv OpenFOAM 4 September 26, 2011 05:59
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 04:15
