Fluid pressure distribution for solid-fluid coupled flows
Old   September 27, 2018, 23:06
Default Fluid pressure distribution for solid-fluid coupled flows
Kahlil Fredrick Cui
cuikahlil is on a distinguished road
Hi!
I would just like to get your ideas on this matter and maybe correct mine if I am wrong. I am simulating a granular flow down an inclined plane which is completely submerged in water. The particles move through cyclic boundaries. I have modeled the fluid phase, in interfoam and icoFoam, using cylic boundaries and inlet-outlet BCs respectively since the flow is pretty much in one direction. The fluid phase by the way is static and only moves in response to the motion of the particles. I have compared the resulting pressures for interfoam and icoFoam but they are very much different. The high pressures in interfoam are at the base while a negative pressure develops at the rear end for icofoam. I have attached the resulting pressure snapshots for reference. I want to use icoFoam for this simulation and interfoam is just used to test. I am just wondering if the difference is only due to the absence of gravity in icofoam or due to wrong boundary conditions?
In addition, I am just curious, is there a way to model a free-surface flow down an inclined plane using icoFoam? Perhaps add a gravity term maybe?
Thank you for any ideas you might have on this issue!
cuikahlil is offline   Reply With Quote
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Pressure distribution on flapping wing in fluid ANSYS ankit.rokr CFX 4 October 28, 2011 11:33
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
