September 12, 2018, 05:07 |
Calculating the Mass transfer
Shankar Lingesh
Rep Power: 8 |
There is a room at 30 degrees Celsius and the ambient temperature is 20 degrees Celsius.I want to know how much mass transfer takes place when I open the door of my room.
I want to model this scenario in CFD. I am relatively new to this field, it would be of great help if someone could help me. Thanks in advance. |
September 12, 2018, 08:35 |
Lucky
Rep Power: 66 |
You want to model the entire building or just the effect? The effect you can model as boundary layer problem between two fluids of different temperature, densities, etc. You are basically doing a laminar natural convection simulation, i.e. laminar flow with gravity enabled.
You need to decide on your model, the geometry etc. Decide on what software/solver you will use. Then you make a mesh. You also need to decide on what equation of state you want to use: ideal gas or non-ideal gas, dry vs wet air etc. |
September 12, 2018, 08:49 |
#3 | |
Shankar Lingesh
Rep Power: 8 |
I want to model the entire building i.e. just a cubical volume with a door surrounded by the ambient (bigger cubical). I am considering ideal gas here.Should this work ? I am planning to use Ansys Fluent to solve. Any further ideas and details would be of great help. Please kindly excuse if my questions were silly/basic. |
basics, fluid mechanics, thermodynamics |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 21:47 |
Mass transfer interaction and DPM | attaullah | Fluent Multiphase | 0 | February 24, 2017 11:34 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
