Finding Hydrostatic Pressure in Water that is Isothermal
Old   September 11, 2018, 12:33
Default Finding Hydrostatic Pressure in Water that is Isothermal
Ziv Melamed
Melamed555 is on a distinguished road
I am an engineering student and I was given a problem to find the pressure at a certain depth. I was given a surface density and a bulk modulus of elasticity. My professor said that we should be incorporating a speed of sound equation to help us find the answer. I solved for the speed of sound correctly and I am assuming that to be constant because of the isothermal assumption. The water is assumed to be compressible so I am having trouble finding the new density. Could someone give me some advice on how to go about starting this? I didn't include the values because I am not looking for the answer. I would prefer to figure that out on my own.
Thanks in advance
Melamed555 is offline   Reply With Quote
Old   September 11, 2018, 12:53
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Be careful about the "compressibility" in water, the pressure increases along the depth as a result of the weight of the above mass of liquid. But we do not have variation of volume.
FMDenaro is offline   Reply With Quote
Old   September 11, 2018, 14:37
agd
agd is on a distinguished road
It sounds to me like you might need to refer back to the fundamental definition of the sound speed as the partial derivative of pressure with respect to density at constant density. A little manipulation can give (for a fluid like water) that this is the derivative of pressure with respect to density at constant temperature. If you assume that the speed of sound is constant, then you can integrate to get a relation between density and pressure.
agd is offline   Reply With Quote
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
hydrostatic pressure influence pdz711 FLUENT 0 June 17, 2008 23:33
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
