How can I make a CFD simulation to calculate energy absorbed by water?
Old   September 11, 2018, 06:38
Default How can I make a CFD simulation to calculate energy absorbed by water?
Laith
Laithalnaser is on a distinguished road
How can I make a CFD simulation to calculate energy (K.E) absorbed by water from a moving object inside it producing work (P.E).
Similarly to the paddle wheel experiment by James Joules.
P.S. Its for a school project! please help
Thank you for your time!
Laithalnaser is offline   Reply With Quote
Old   September 12, 2018, 08:42
Lucky
You need to be way more specific. What software you are using, etc. What is your actual geometry? How do you plan to model it?
Let's suppose I was simulating the paddle wheel experiment by Joules. I'd mesh me a circular tank with some walls to represent the paddle wheel. Then I'd go into one of my favorite CFD programs. I'd assign a rotational velocity to some of these walls. I could assign it to the paddle wheel or I can just assign it to the tank walls and have the paddle wheel stationary and the tank spinning (not what Joule did, but you get the same effect).
I'd probably pick constant density water with all material properties constant just to simplify things. Then I'd set up a bunch of settings and calculate it steady state as a laminar flow and just integrate over the volume the viscous dissipation and I'll get a number with units of Watts. In some software like Star-CCM the viscous dissipation is always calculated. In Fluent it must be activated. In OpenFOAM you have to do some more things. And then you could spice it up even more and do a transient simulation to actually do what Joule did. Set the initial temperature to ambient condition and do many many many time-steps and watch the temperature rise to the boiling point. Of course if I use a constant density equation of state, I'll never get to see the water boil the same way as Joule.
Pressure value too low for water simulation hokhay OpenFOAM 6 July 27, 2017 13:37
How to calculate torque of the shaft for turbines in CFD fluent simulation ? jeevmech FLUENT 0 September 25, 2016 00:30
to make a air bubble in a water tank simulation harshrox3 FLUENT 0 November 8, 2015 16:12
cfd simulation of solar water heater using cfx 13.0 avinash madhavan CFX 14 January 9, 2012 18:11
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
