interfoam: set a velocity to 0 when alpha is low
Old   August 30, 2018, 12:21
Default interfoam: set a velocity to 0 when alpha is low
Kahlil Fredrick Cui
cuikahlil is on a distinguished road
Hi!
I want to set the velocity of a cell to 0 if the value or alpha1 (water phase) is less than a certain value (like <0.01) since I want to reduce the velocity of air
I implemented this in Ueqn right after the convective term:
forAll(U, celli)
		if (alpha1[celli] < 0.01)
			U[celli] == vector(0.0,0.0,0.0);
but it doesn't re-assign the values.
Maybe I'm positioning the code wrong? or it the way it is written?
Any help would be very much appreciated. Thank you!
cuikahlil is offline   Reply With Quote
interfoam
particle velocity field from twoPhaseEulerFoam when particle volume fraction is low openfoammaofnepo OpenFOAM 0 June 28, 2017 19:51
interFoam, nonuniform alpha for channel flow KTG OpenFOAM Pre-Processing 0 February 23, 2017 23:41
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result. sharonyue OpenFOAM Running, Solving & CFD 12 April 10, 2016 00:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
