August 30, 2018, 07:24 |
Fastest CFD Solvers
James
Rep Power: 8 |
What would everyone say is the fastest CFD solver in the world?
August 30, 2018, 07:53 |
Rep Power: 8 |
It is a question of accuracy vs. computing resources, not which one is the fastest. Being twice as fast but ten times less accurate than any solver is not difficult.
August 30, 2018, 08:01 |
Philipp Wiedemer
Rep Power: 9 |
That depends on a lot of things, to name a few:
- The hardware you're running on - Mesh-size - Your type of simulation, boundary conditions etc. - What you define as fast For example coupled solvers generally take longer for a timestep compared to uncoupled solvers but reach convergence in less timesteps. The commercial solvers are probably pretty good and on equal ground I'd suspect. I don't think there is a fastest solver because it always depends on your specific use case and what you want to achieve. |
August 30, 2018, 08:03 |
James
Rep Power: 8 |
Ok so what would you think the strengths and weaknesses of ANSYS Fluent are?
August 30, 2018, 08:25 |
Philipp Wiedemer
Rep Power: 9 |
Not a fluent user myself, but as I heard fluent has a wider range of applications and more variety compared to CFX for example.
There are a lot of threads concerning this topic in this forum. |
August 30, 2018, 11:30 |
#6 | |
Lucky
Rep Power: 66 |
Heck even within Fluent there's a about a dozen different solver combinations that each have strengths and weaknesses over one-another. And to bring back an example already mentioned the coupled solver is nice and converges faster when you are talking about 1 cpu, but it doesn't parallelize well and eventually the slower converging but more parallel-friendly segregated approaches (SIMPLE/PISO) can catch up if you run it on a big enough machine. And this isn't Fluent's fault, it's the algorithm. Fluent is just another piece of code. |
cfd, fastest, solver, world |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 18:09 |
Current state of Open Source vs Commercial CFD solvers | Stab | Main CFD Forum | 42 | January 10, 2016 07:23 |
Comparison of CFD solvers for Hydrodynamic problem | furkan | Main CFD Forum | 0 | August 22, 2006 12:00 |
Iterative equation solvers in CFD | Vitaly Bulgakov | Main CFD Forum | 32 | March 1, 1999 12:11 |
CFD Symposium (Call for Papers) | Chris R. Kleijn | Main CFD Forum | 0 | October 5, 1998 11:25 |
