mesh sensitivity study
Old   August 24, 2018, 13:05
Question mesh sensitivity study
pangxiongx
pangxiongx is on a distinguished road
Hello all,
I am doing mesh sensitivity studies of a rod bundle flow channel with star-ccm+. In the middle part of the channel there are mixing vanes - obstacles basically.
I divide the whole domain into three regions: region_1: "clean" channel upstream of the obstacles; region_2: channel containing the obstacles; and region_3: "clean" channel downstream of the obstacles.
For region_1 and 3, extruded (or directed) hexahedral mesh can be easily created; in region_2, since geometry is complicated because of obstacles, automatic trimmed mesh is used. The regions are connected with two interfaces.
My question is: while doing mesh sensitivity study in my case, can I do it separately on hexahedral and trimmed mesh, respectively? After the best mesh has been determined for both hexahedral and trimmed mesh, connect them with interfaces and then calculate the whole domain. Or at least after this process, in order to consider the wake flow downstream of obstacles, maybe I can only refine the mesh in region_3 in the axial direction (instead of 3 directions)?
Any hint or comment is appreciated. Thanks in advance!
Kind regards,
Pangx
pangxiongx is offline   Reply With Quote
mesh sensitivity
[ICEM] Mesh Independence study Carlos Modesto ANSYS Meshing & Geometry 4 July 7, 2017 07:57
Mesh Independent Study isuru Main CFD Forum 17 March 26, 2013 12:35
[ANSYS Meshing] Any way around mesh study using mesh stats? Torque_Converter ANSYS Meshing & Geometry 5 June 4, 2012 11:07
Mesh sensitivity when using phase change models BKaus STAR-CCM+ 0 February 28, 2012 21:51
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
