February 15, 2021, 12:49 |
#61 | |
Also, would you be able to use it for me if I pass you a vector of 24 values? |
February 15, 2021, 12:52 |
#62 |
Filippo Maria Denaro
Rep Power: 73 |
The example that Paolo asked for is sneaky ... It is what you can see reported in this example
https://upload.wikimedia.org/wikiped...asing-plot.png You can also simplify the example and forget about using two frequencies, just use a single k for the sine function and try for values of k that are lower than the Nyquist one and then for values greater. The key is how the aliased function is recognized. A further exercize is to sample the function on a grid and performing the FFT to recognize the frequency. When the function is aliased you get an aliased spectrum from which you should be able to recognize the original function. |
February 15, 2021, 12:57 |
#63 |
Rep Power: 5 |
playing games with people is not helpful
February 15, 2021, 13:15 |
#64 | |
Note that k1 can be deterministically determined without doubts when and are known. That's what the FFT does. k2, in contrast, is lost information and, as your example helped me to clarify, cannot be determined without assuming some prior knowledge about it. I want to stress that I see no problem at all in this very fact, that a ML algorithm needs some prior knowledge to determine things like k2 in this example. But that's what turbulence modeling is all about, but with very limited prior knowledge, that can't realiably be used in all scenarios. |
February 15, 2021, 14:21 |
#65 |
I probably owe you an apology for the time you wasted, because the phrasing I used to formulate the question was such that it wouldn't filter out legitimate approaches using legitimate reasoning in ML, as your was.
But this was intentional for those that, differently from you, wouldn't recognize thr very need for prior knowledge in such experiment. Sorry again |
February 16, 2021, 01:14 |
#66 |
TP
Rep Power: 5 |
February 16, 2021, 01:21 |
#67 |
TP
Rep Power: 5 |
we're exploring different use cases of AI in CFD at my company. Please feel free to roast me as I am a novice in CFD (was stupid enough to listen to my advisor to focus on freaking lubrication theory for my thesis. This is another case of intellectual masturbation circle that Paolo kind of mentioned above) and ML:
1. In manufacturing control, it's nice to have CFD result online to develop control schemes. But a typical CFD simulation takes too long -> ML to interpolate the cases in between. 2. Design: do not need to run a new CFD sim each time we want to try a new geometry. |
February 16, 2021, 04:38 |
#68 | |
Rep Power: 73 |
What Paolo addressed is something resembling what a "perfect" LES should do, that is resolving a range of frequency up to Kc and "deducing" the contribute of the unresolved frequency for k>Kc. The question is: what new contribution AI is able to do in this framework? |
February 16, 2021, 12:11 |
#69 | |||
Let me start this post with an apology, again. I want to stress that none of the points I am going to elaborate further is, in any way, related to any particular individual. Still, I might generically refer to the situation of someone that, while practicing in a certain field, might not be sufficiently equipped, for a mere lack of time invested, to do so. This reference, again, is not to anyone here in particular, hence the apology in case anyone might feel otherwise.
I already did this in one of the early posts in this thread, but let me recap how, today, is ML applied in CFD, to the best of my knowledge, with my perceived pros and cons. 1) To produce a reduced order model (ROM) of the CFD case under investigation, where few relevant input parameters are mapped to few relevant output parameters. That is, few scalars as input and few scalars as output. This is one of the oldest ways ML has been applied to CFD and, probably, one of the most legit and sound. ROM are a necessity in several kind of studies, and ML techniques are very well suited to this. Still, there is a plethora of statistical/mathematical techniques that achieve the exact same result (some actually linked to the ML ones). So, one thing is if you know all of them (as I would expect from a professional) and can legitimately suggest to use a very specific ML one for a number of reasons; it is different instead if you just know ML approaches and just propose them. 2) To produce some sort of classification of the flow field in a given CFD case or for different CFD cases. Not only this is probably older than the previous use case, but almost all the techniques in unsupervised ML were actually known previously from other fields and extensively applied in CFD way before ML was. Here I must be tougher: if someone doesn't recognize an svd, a pod or an fft for what they are, can't we say that he hasn't a proper recognition of the field? Again, there probably are ML techinques that don't compare to previous ones but, from a CFD expert, I expect to see an informed decision, whatever technique is picked up in the end. 3) As surrogate of a specific model entering the CFD computation. This might be the turbulence model, or the combustion model, etc., but I don't have the competences to judge anything beyond the turbulence modeling, to which I'll stick strictly. Also, I don't expect the same criticalities to be present in every domain of application. First of all, this existed since before google. Some of the people working on this today were around back then as well but couldn't care less. As for the points above, what the last decade essentially bringed to the table is availability at large of computational resources, data (i.e., DNS and LES data, which again have flourished because of the availability of computational resources) and specialized tools. Which, however, I agree are good incentives. Second, for those who need some professor words to understand their own field, here it is an excerpt from an abstract of a recent paper on the subject (which, however, I won't cite on purpose): Quote:
What we typically do in a CFD computation is solving for a dynamical system which has been deprived of some degrees of freedom. The very problem of these missing degrees of freedom is that they are completely lost in our description as no information about them is present among the degrees of freedom we retain, yet they have a relevant role in the overall dynamics of what we want to describe. What the turbulence modeling comunity has traditionally tried to do is to come up with some model that, only knowing the retained degrees of freedom, was able to mimic the overall system dynamics by embedding in the model what we know about the functional role of the missing degrees of freedom. This is the case, for example, of the Smagorinsky model (and similar ones) in LES. Depending from the case, the community also found out that the more embedded prior information we used the better it was. For example, in RANS, additional transported quantities are typically used for turbulence models, with 2 equation models tipically outperforming 1 equation or algebraic models. What is important to recognize, however, is that such embedded prior information then automatically becomes part of the degrees of freedom that we retain. That is, if we use a k-something model with boundary conditions for k, you are automatically assuming that you know k and its boundary conditions and that you can describe its evolution (much like you do with the pressure or velocity components). This distinction is important as otherwise it might seem that having an equation for k you are automagically accessing some of the missing degrees of freedom in your representation. You are not, you are just making a promise that you also know k and how it interacts with your other equations. Now, a very basic exercise that is usually proposed in turbulence classes is trying to derive equations for the unclosed terms in the RANS equations. You derive the Reynolds stresses equations, but they have more unclosed terms that need modeling. You derive equations for those unclosed terms, and even more unclosed terms appear, and so on indefinitely. That is, doesn't matter how many promises you make in a RANS context, as long as they are in finite amount they are not complete. When a novice imagines a perfect turbulence model he misses this very fundamental truth. Whatever you come up with, it can't be perfect because it has a limited amount of information in it, while you would need an infinite amount, even for a single given flow. Another thing that novices usually miss is the fact that, for a given state of the retained degrees of freedom, there are infinitely many compatible states of the missing degrees of freedom. So, independently from where you stop your promises, there will still be infinitely many possible states of the missing degrees of freedom. In practice you need an infinite amount of information that, unfortunately, is also compatible with an infinite amount of states. Then comes the main, rethorical, question (so that I won't answer): can a ML technique learn and store an infinite amount of information? Because that's what the turbulence modeling problem is, at least in part. In practice, the problem is not so hard and desperately destined to remain completely unsolved, but it is, and has always been, a not well posed problem. Now, I see promises in how ML can actually advance the field in several aspects. But anyone expeting miracles from ML in this respect, I conclude, is not aware of the basics in the field and, to some extent, physics/logics in general. The whole reasoning, when performed in LES just becomes more clear, as you have resolved and missing spatial scales, which are more easily relatable to. My sin experiment explicitly referred to LES, even if not exactly. The point being that if you don't have access to information below the grid, then you don't, end of the story. Your ML algorithm can spend years learning, but there will always be infinitely many states to learn, and the DNS data we have currently access to is also ridicolously limited with respect to the current application of CFD in industrial problems. Have interesting results been produced in this area of ML applied to CFD? Of course, but anyone screaming miracle is out of his league. An area where I especially see possible positive outcomes is in the wall function one, where embedding additional physics beyond the basics has always been problematic to achieve at low cost. 4) As surrogate for a real CFD computation. There are, today, techniques that allow to get the whole flow field from the same information you would use in an actual CFD computation. This, I think, is incredible, and one of the most promising applications in CFD. But, and this is really important, we need to agree on some fundamental aspects. Not only there are infinitely many states of turbulence, but also geometrical/topological configurations, combinations of physical models. So, expecting a single ML algo to be able to generalize to all the possible physical combinations is, again, overly optimistic. In the same vein of previous points however, using a ML technique to predict a potential flow is, instead, not miracolous at all (because beyond geometry it has to just learn a single kernel function) and of limited practical value. Beyond video games, I see potential in inlet/initial value generation and some, hopefully controlled, ROM scenarios. Quote:
Yes, the example was indeed very limited, but I think the issue is also more general, as I tried to elaborate above in point 3 |
February 16, 2021, 13:03 |
#70 |
With respect to my previous sin example, I also want to add that, a recent paper in JFM, again, addresses the use of ML for the so called super-resolution LES, basically attempting at reconstructing velocity fields beyond the grid cut off .
For some strange reason this not well posed problem, that is inevitably destined to produce noise (or just what is previously embedded in it), keeps having space in such a reputed journal. You would at least expect that the most relevant information, the spectra of such super resolution reconstruction, would be central in such works, but as they just produce crap/noise, they are obviously relegated to a single picture, well hidden, where reality is just ignored and the results described with kindergarten terms. This is just to say that nothing of what I wrote is random. There is a relevant problem in how ML is used in certain technical fields. Not sure about the reason, but still a problem. |
March 15, 2021, 00:03 |
#71 |
TP
Rep Power: 5 |
Has anyone seen this?
Now they want to predict weather with AI lol: https://www-technologyreview-com.cdn...equations/amp/ |
March 30, 2021, 00:32 |
#72 |
Kira
Rep Power: 9 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 09:10 |
CFD JOBS and Expected Salary.... | Noel Harrison | Main CFD Forum | 11 | November 22, 2000 08:15 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
