August 13, 2018, 06:22 |
MacCormack's solution of Shock tube problem
thecampusgirl
Rep Power: 8 |
Hello Im working on numerical solution of Sod Shock tube problem. I have written matlab code using Lax Friedrichs. Now I wanna write matlab code with MacCormack two step scheme.
My code is working but atfer some steps I got NaN values so I can not obtain my figures. If you can look my code and give any idea for solving this problem I will be thankful. And density start at 0.5 instead of 1 I dont understand why this happen. Here the code that I write in MATLAB ; clear all; close all; clc; nx = 101; % Initialization r = zeros(nx,1); u = zeros(nx,1); E = zeros(nx,1); p = zeros(nx,1); x = zeros(nx,1); Q = zeros(nx,3); F = zeros(nx,3); Qnew = zeros(nx,3); c = zeros(nx,1); % Parameters gamma = 1.4; CFL = 0.68; tMax = 0.2; dx = 1/(nx-1); % Creating mesh for i=1:nx x(i) = (i-1)*dx; end % Initial condition for i=1:nx if (x(i) > 0.5) p(i) = 0.1; r(i) = 0.125; u(i) = 0.0; elseif (x(i) <= 0.5 ) p(i) = 1.0; r(i) = 1.0; u(i) = 0.0; end E(i) = p(i)./(gamma-1) + 0.5*r(i)*(u(i).^2); c(i) = sqrt(gamma*p(i)/r(i)); end % Q_new will be the solution vector Qnew(:,1)=r; Qnew(:,2)=r.*u; Qnew(:,3)=E; t=0.d0; % Time loop while (t<tMax) dt = CFL*dx./(max(max(c+sqrt(u.*u)))); for i=1:nx % Flux calculation Q(i,1) = r(i); Q(i,2) = r(i).*u(i); Q(i,3) = E(i); F(i,1) = r(i).*u(i); F(i,2) = r(i).*u(i).^2 + p(i); F(i,3) = u(i).*(E(i) + p(i)); end for i=2:nx-1 % predictor step Qstar(i,1) = Q(i,1) - (dt/dx)*(F(i+1,1) - F(i,1)) ; Qstar(i,2) = Q(i,2) - (dt/dx)*(F(i+1,2) - F(i,2)) ; Qstar(i,3) = Q(i,3) - (dt/dx)*(F(i+1,3) - F(i,3)) ; % Corrector step ustar(i) = Qstar(i,2) / Qstar(i,1); pstar(i) = (gamma-1)*( Qstar(i,3) - 0.5*(Qstar(i,2).^2/Qstar(i,1)) ); Fstar(i,1) = Qstar(i,1).*ustar(i); Fstar(i,2) = Qstar(i,1).*(ustar(i).^2) + pstar(i); Fstar(i,3) = ustar(i).*( Qstar(i,3) + pstar(i) ); Qnew(i,1) = 0.5* (Qnew(i,1) + Qstar(i,1) - (dt/dx) * (Fstar(i,1) - Fstar(i-1,1))); Qnew(i,2) = 0.5* (Qnew(i,2) + Qstar(i,2) - (dt/dx) * (Fstar(i,2) - Fstar(i-1,2))); Qnew(i,3) = 0.5* (Qnew(i,3) + Qstar(i,3) - (dt/dx) * (Fstar(i,3) - Fstar(i-1,3))); end % Boundary condition Qnew(1,: ) = Qnew(2,: ); Qnew(nx,: ) = Qnew(nx-1,: ); % Primitive variables r = Qnew(:,1); u = Qnew(:,2)./r; E = Qnew(:,3); p = (gamma-1)*(E-0.5*r.*(u.*u)); t=t+dt; % Advance in time end plot(x,r); figure(1) xlabel('x'); title('Density'); Last edited by mathgra; August 13, 2018 at 10:05. |
August 14, 2018, 08:54 |
Rep Power: 16 |
I think I can see one coding mistake. In the corrector step you use Fstar(i-1,: ). As the components of Fstar are defined in a loop from 2 to nx, Fstar(1,: ) is never computed.
Second comment, probably not critical here, in general it is better to update the speed of sound inside the temporal loop for dt computation |
August 14, 2018, 09:06 |
#3 | |
thecampusgirl
Rep Power: 8 |
Oh you are right, Thanks a lot I added Fstar at boundary as Fstar(1,: ) = Fstar(2,: ); Fstar(nx,: ) = Fstar(nx-1,: ); but density still start with 0.8 its really interesting |
August 14, 2018, 09:24 |
#4 | |
thecampusgirl
Rep Power: 8 |
thank you so much for advise the place that I put Fstar boundary was wrong. Now it works Im so much thankful |
August 14, 2018, 09:27 |
Rep Power: 16 |
All right well done!
April 12, 2020, 15:07 |
Volkan
Rep Power: 7 |
Hi mathgra,
I am trying to use your code to have a basic understanding of the mccormick solution, but i keep having error "Undefined function or variable 'Fstar'. " I don't know what I am doing wrong. Thank you |
January 28, 2023, 21:10 |
Rep Power: 13 |
Please share your updated code for Maccormack. I am also working on the same for understanding.
1D Shock Tube problem | RamShivam | Main CFD Forum | 3 | June 13, 2018 09:37 |
Sod Shock Tube solution using Nodal DGFEM 2D CNS Solver | Quasar_89 | Main CFD Forum | 0 | July 30, 2016 08:22 |
Analytical solution for the Shock Tube | Farouk | Main CFD Forum | 0 | July 12, 2013 08:16 |
ghost fluid method (shock tube problem) | Amir | Main CFD Forum | 0 | March 1, 2009 06:16 |
ENO Scheme in a Shock tube problem | Shiv | Main CFD Forum | 4 | January 29, 2007 15:31 |
