August 6, 2018, 08:32 |
Freeze Flow for Transient Heat Up Simulation
Rep Power: 10 |
I am trying to do a simulation of a cold room, which sees an blower with hot air. If I switch on the blower and wait for 30min, the room is more or less in a stationary condition. When I am trying do simulate this transient process, I am wondering, if I can use a fleeze flow condition after a couple of iterations. Yes, due to my blower I have many turbulence and vortexes in my room, but I assume, that the flow field can be assumed to be converged after a couple of seconds (60s) . After this, I would switch on "freeze flow" option. Do you think this can work? I am not quite sure if I have a highly turbulent flow and I switch on freeze flow to reduce computing time? Thank you for any hints guys! |
August 6, 2018, 10:39 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
No, I don't think that is correct, the fluid is air and Pr=O(1), the bouyancy is relevant and the flow is turbulent. |
August 7, 2018, 14:10 |
Lucky
Rep Power: 66 |
If that is the justification I would verify that the flow is stationary, which requires doing the transient simulation with flow on.
But if you are only looking for a crude answer then it would certainly be helpful to freeze the flow. It depends why you are doing CFD and what you hope to get out of it. |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 09:50 |
heat transfer simulation of 3D laminar flow in uniformly heated tube | engrmansoor2534 | FLUENT | 0 | May 7, 2015 07:23 |
New guy trying to solve his first simple Heat Transfer simulation. | BhaluBear | OpenFOAM | 2 | August 12, 2014 13:54 |
3d flow simulation of staggered fin tube heat exchanger | mallikarjuna | FLUENT | 0 | April 10, 2014 07:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
