Is it possible to make a partly-symmetric model in FLUENT/CFX?
Old   July 31, 2018, 15:28
Default Is it possible to make a partly-symmetric model in FLUENT/CFX?
Lee Strobel
Time4Tea is on a distinguished road
I'm wondering if there is any way in either FLUENT or CFX to construct a model that is partly-symmetric - i.e. symmetric only in one particular local region?
For example, I am currently trying to model internal flow in a valve, where in the center, the fluid is flowing outwards through a diffuser that consists of a cylindrical component with hundreds of radial holes. Trying to model all of those holes individually will be computationally very expensive; however, I expect the flow field through each one to be largely similar. Although, the flow through the rest of the valve beyond that is not radially symmetric (it only has half-symmetry), so it would not be accurate to model the entire valve as radially-symmetric.
So, is there some way in either of these packages that I could model this cylindrical diffuser as a symmetric component - i.e. just mesh and solve one hole or one slice of the cylinder - but then extrapolate and reconstruct the combined flow field for the whole diffuser and apply that to the flow field in the rest of the valve geometry?
I hope my question is clear enough, if not then I will try to clarify further.
Time4Tea is offline   Reply With Quote
Old   August 3, 2018, 15:53
Lucky
Yes but you have to become very skillful at creating interfaces. And usually it is much faster to solve the full non-simplified model than learning how to create these interfaces.
Old   August 3, 2018, 16:28
Lee Strobel
Ok, thanks for the advice, LuckyTran. Out of interest, is that possible in both FLUENT and CFX, or just CFX?
cfx, fluent, symmetry
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 04:46
How to model PCM based heat storage in fluent/cfx S.Karthikeyan CFX 2 September 22, 2011 11:58
shocks in a 1-d spherically symmetric model Alex Main CFD Forum 2 August 20, 2008 07:53
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 17:45
