Encountering an error while running a case in cluster using openfoam
Old   July 31, 2018, 02:29
Default Encountering an error while running a case in cluster using openfoam
Suman Dathathreya
dnsuman is on a distinguished road
Hi
I am currently doing a project related to aircraft wings. While executing the analysis I get an error.
To run the case i had used
/usr/bin/mpirun --hostfile machines -np 8 simpleFoam -parallel
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[1]
[1] From function [2]
[2]
[2] --> FOAM FATAL ERROR:
[2] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[2]
[2] From function static bool Foam::UPstream::init(int&, char**&)
[2] [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[3]
[3] From function static bool Foam::UPstream::init(int&, char**&)
[3] in file UPstream.Cstatic bool Foam::UPstream::init(int&, char**&)
[1] in file UPstream.C at line 103.
[1]
FOAM parallel run aborting
[1]
[4]
[4]
[4] --> FOAM FATAL ERROR:
[4] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[4]
[4] From function static bool Foam::UPstream::init(int&, char**&)
[4] in file UPstream.C at line [5]
[5]
[5] --> FOAM FATAL ERROR:
[5] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[5]
[5] From function static bool Foam::UPstream::init(int&, char**&)
[5] in file UPstream.C at line 103.
[5]
[2]
[2]
at line 103.
[3]
[3]
[6]
[6]
[6] --> FOAM FATAL ERROR:
[6] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[6]
[6] From function static bool Foam::UPstream::init(int&, char**&)
[6] in file UPstream.C at line 103.
[6]
[6]
103.
[4]
[4]
[0]
[6] #0 [0] [4] #0 Foam::error:rintStack(Foam::Ostream&)--> FOAM FATAL ERROR: [5] #0 Foam::error:rintStack(Foam::Ostream&)
Foam::error:rintStack(Foam::Ostream&)[3] #0 [2] #0 [1] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)Foam::error:rintStac k(Foam::Ostream&)[0] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[0]
[0] From function static bool Foam::UPstream::init(int&, char**&)
[0] in file UPstream.C at line 103.
[0]
[0]
[0] #[7]
[7]
[7] --> FOAM FATAL ERROR:
[7] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[7]
[7] From function static bool Foam::UPstream::init(int&, char**&)
[7] in file UPstream.C at line 0103.
[7]
[7]
Foam::error:rintStack(Foam::Ostream&)[7] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[2] #1 Foam::error::abort() at ??:?
[3] #1 Foam::error::abort() at ??:?
[4] #1 Foam::error::abort() at ??:?
[5] #1 Foam::error::abort() at ??:?
[6] #1 Foam::error::abort() at ??:?
[1] #1 Foam::error::abort() at ??:?
[7] #1 Foam::error::abort() at ??:?
[0] #1 Foam::error::abort() at ??:?
[2] #2 Foam::UPstream::init(int&, char**&) at ??:?
[4] #2 Foam::UPstream::init(int&, char**&) at ??:?
[5] #2 Foam::UPstream::init(int&, char**&) at ??:?
[1] #2 Foam::UPstream::init(int&, char**&) at ??:?
[6] #2 Foam::UPstream::init(int&, char**&) at ??:?
[3] #2 Foam::UPstream::init(int&, char**&) at ??:?
[2] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[5] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[4] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[1] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[6] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[3] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[7] #2 Foam::UPstream::init(int&, char**&) at ??:?
[0] #2 Foam::UPstream::init(int&, char**&) at ??:?
[2] #4 at ??:?
[0] #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:?
[5] #4 at ??:?
[4] #4 at ??:?
[7] #3 Foam::argList::argList(int&, char**&, bool, bool, bool)?? at ??:?
[1] #4 ? at ??:?
[3] #4 at ??:?
[6] #4 in "/usr/bin/simpleFoam"
[2] #5 __libc_start_main? at ??:?
[0] #4 in "/usr/bin/simpleFoam"
??[5] #5 __libc_start_main at ??:?
[7] #4 in "/usr/bin/simpleFoam"
[4] #5 __libc_start_main? in "/usr/bin/simpleFoam"
[1] #5 __libc_start_main in "/usr/bin/simpleFoam"
[3] #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #6 in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #6 in "/lib/x86_64-linux-gnu/libc.so? in "/usr/bin/simpleFoam"
[6] #5 __libc_start_main.6"
[4] #6 ?? in "/usr/bin/simpleFoam"
[0] #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #6 in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #6 in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #6 in "/usr/bin/simpleFoam?"
[7] #5 __libc_start_main in "/usr/bin/simpleFoam"
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
?? in "/lib/x86_64 in "/usr/bin/simpleFoam"
[0] #6 in "/usr/bin/simpleFoam"
? in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #6 in "/usr/bin/simpleFoam"
?[linux:18216] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[linux:18216] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I've set up the nfs server and client and also enabled the passwordless ssh. I need help as I am new to openfoam.
dnsuman is offline   Reply With Quote
Old   August 3, 2018, 17:20
Lucky
Are you sure that is the right commands to run on your cluster? I.e. try instead
/usr/bin/mpirun -np 8 -machinefile machines simpleFoam -parallel
Old   August 6, 2018, 02:35
Suman Dathathreya
Hi
Sorry for the late reply. I had tried the code that you mentioned I got the same error as mentioned in my above post
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
Difficulty running an inviscid compressible nozzle flow using OpenFOAM rbozinoski OpenFOAM Running, Solving & CFD 11 December 29, 2015 08:19
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
How to install the OpenFoam in the cluster. Please help me! flying OpenFOAM Installation 6 November 27, 2009 04:00
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
