July 30, 2018, 12:50 |
Spacecalim multibody domain
ali
Rep Power: 18 |
Hi all,
I am new to Spaceclaim. I was quite good with the design modeler. I cannot add multiple bodies into spaceclaim. I could easily do it in design modeler using add frozen option. Everytime I open an object in spaceclaim, it opens it as a separate object. Sorry if the question sounds a bit primitive. But I searched and could not find anything. Hoe can I fix it? Thanks, |
July 30, 2018, 23:06 |
please mention your problem clearly
Taiwan,new north city
Rep Power: 9 |
Dear Ali,
what you mean by multiple bodies? i could not able to understand your question. please explain clearly. Thanks... |
July 31, 2018, 12:43 |
ali
Rep Power: 18 |
let's assume that I want to have multiple domains and I have a separate geometry for each one. How do I import them into Spaceclaim. I used to be able to easily do it in the design modeler using "import geometry" and "add frozen option"
August 1, 2018, 00:39 |
suggestions
Rep Power: 9 |
hi,
you mean you have multiple parts/geometry file in your assembly right? 1.try to assemble in cad software such as solid works or solid edge etc... 2. save a file format to (STEP or para-solid xt or igs ) 3. then import into spaceclaim 4. if you dont have assembly file (with all seperate parts) you need to combine in spaceclaim Thanks... |
January 22, 2020, 07:14 |
cfd-simulant
Maybe you can find the answer her:
look at Step 5 - Prevent multi-body parts in ANSYS-Workbench http://help.spaceclaim.com/2015.0.0/...rial_Step1.htm In my SpaceClaim-Testcase it works fine. |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 22:05 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Appropriate Boundary conditions for jet flow in open domain | shrutidhara.123 | FLUENT | 0 | August 5, 2014 11:27 |
Different diffusivity for additional variable in Fluid and porous domain | ftab | CFX | 4 | June 27, 2012 14:03 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 11:31 |
