How to run SU2 on HPC cluster in parallel on HPC cluster?
Old   July 13, 2018, 01:44
Wink How to run SU2 on HPC cluster in parallel on HPC cluster?
Samir Shaikh
Samirs is on a distinguished road
Hi All,
I installed SU2 code on CentOS 7 without any error reported and passes all tests provided with source code. When I'm running it on login node using parallel_computation.py script everything works fine, but running same script on compute node hangs execution without termination/error. On compute node it is only using single core of a node. I am using SLURM for job schedulling.
I observed that whenever I'm running same script by establishing SSH connection to compute everything works fine.
Any input on this will be appreciated
Samirs is offline   Reply With Quote
su2, su2 ad openmpi gcc, su2 bug, su2 error
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
Problem with foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 1 December 6, 2018 16:51
Problem in foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 0 February 20, 2018 07:34
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Scaling for parallel run for SU2 nileshjrane SU2 1 January 1, 2015 21:06
