Temperature dependent properties relation
Old   July 11, 2018, 04:34
Default Temperature dependent properties relation
A. Min
alimea is on a distinguished road
Hi all
I want to simulate a forced convection that is report in paper:
Accounting for temperature-dependent properties in viscoelastic duct flows
by Nobrega.
Like the other papers, all of the results are reported in non-dimensioned form. I have calculated initial and boundary conditions based on these dimensionless numbers.
Dimensionless temperature is defined as:
T*=(T-Ti)/(Ts-Ti)
where Ts and Ti are wall and inlet temp. Scince the real or physical values of Ts and Ti are not mentioned in the paper, I decided to select to arbitrary values like 1 and 0 respectively.
Viscosity is changing with
etta(T) = etta0 * aT
where
aT = exp [a(1/T-1/T0)]
where T0 = 463 K and a = 1720 K
Now I have a question:
My T* values that are come from BC, IC or from the energy Eqn are dimensionless, how can I put these dimensionless values in a relation with real physical To and a ?!!!
Thanks
alimea is offline   Reply With Quote
dimensionless temperature, temperature dependence
Temperature dependent values in dependence of K? h0rst FLUENT 0 February 2, 2017 14:46
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Temperature dependent on air properties Reto CFX 1 September 9, 2010 19:52
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
