June 14, 2018, 00:35 |
NREL Phase VI Structure Modeling
Ahmed Riyadh Ali
Rep Power: 9 |
Dear All
I am trying to establish a 1-way FSI on the NREL Phase VI wind turbine using a single blade. I am trying to get as many structural properties of the blade by going through various literature including the unsteady aerodynamics experiment phase vi wind tunnel test configurations. However, all I get is mass and stiffness distribution along the span and the weight of the blade. The properties of the composite materials used as well as the variable thickness of the layup are not available. So my inquiry is that: is there a possible method to use the mass and stiffness distribution as an input data to Ansys Mechanical or even use a third party code first and export the model to Ansys later. Thanks |
fsi, nrel phase 6 |
Evaporative phase change modeling in FLUENT | Kimia | Fluent Multiphase | 7 | May 26, 2020 00:19 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
Verification of this phase change modeling | kawamura | OpenFOAM | 4 | December 21, 2011 00:14 |
Verification of this phase chage modeling | kawamura | ANSYS | 0 | December 14, 2011 03:40 |
PEMFC with two phase flow modeling | H.M.F | FLUENT | 0 | April 3, 2008 07:04 |
