Wind tunnel model of an animated cyclist
Like Tree1Likes
Old   October 26, 2018, 20:42
Tigre is on a distinguished road
The helmet was just an example, and yes the head can move a lot! I am interested in time-trial applications so think more about "aerodynamic" helmets. A static solution if accurate enough to detect the change between two different helmets (about 0.005 change in CdA) would be a good start.
Optimizing the shape bicycle shoes is another example and would be more complex to solve...
Tigre is offline   Reply With Quote
Old   October 29, 2018, 00:17
I struggle to define vertices adapted to my .stl file in blockMeshDict...
Bounds of my object are:
x range: -0.494534 to 0.498245 (delta: 0.99278)
y range: 0.996753 to 1.76781 (delta: 0.771054)
z range: -1.34513 to -0.209654 (delta: 1.13548)
How should I define the vertices in blockMeshDict given this?
Old   October 29, 2018, 01:20
Don't lose your time for this question, I found a very good tutorial that could help others here: http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf
aerodynamic forces, wind tunnel simulation
Wind Tunnel Blockage question ohma0043 CFX 9 June 17, 2018 20:19
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
CFD Model of a Small Open Jet Wind Tunnel rfar0028 Main CFD Forum 0 November 20, 2011 10:24
Wind tunnel simutalion in Rampant Md. Shahiduzzaman Khan Main CFD Forum 6 February 18, 1999 14:15
wind tunnel correction Arthur Chen Main CFD Forum 2 September 4, 1998 19:42
