Contour plotting
Old   April 14, 2000, 12:00
Default Contour plotting
Mark Russell
Hi, I have written a piece of code to solve some simple heat transfer problems and to display the output also have written a simple contour plotting routine. The output could be better but because of the simplicity of my code I don't want to spend all my efforts developing the post-processing component.
Does anybody out there have, or know of, a 'free' contour plotting routine that I can drop into my program.
For reference my 'parent code' has been developed in an early version of MS Visual C++ and runs under MS Windows.
Thanks in advance.
Old   April 16, 2000, 13:43
Default Re: Contour plotting
John C. Chien
(1). Try the commercial post-processor programs or the vendors. (2). The graphic program is much harder to write and it is usually much longer than the solver part.
Old   April 17, 2000, 04:17
Esam Alawadhi
Hello, Try Mathematica it can do it.
Old   April 18, 2000, 18:23
Ahmed Al-otaibi
Hi .. I suggest you to spend more time and improve ur code... It will be good exercise for you...I will give a hint: "It is matter of interpolation to have the iso-lines".. If u gave up just contact me i have it in visual basic.. Hope you good luck
Old   April 21, 2000, 10:51
C.B. Jiang
Try to use Surfer or Origin.
Old   April 22, 2000, 23:45
S. I. Haider
Try Matlab 5.3. It is a great package for plotting contours. As a matter of fact you can automate the whole process by generating the corresponding C++ code by using the Matlab Graphics Compiler and embedding the resulting code in your application.
Reynolds contour plotting in cfx-post mortazavi CFX 3 June 3, 2009 08:34
Vof contour plotting Shane FLUENT 1 October 8, 2006 05:57
CONTOUR PLOTTING Dr M.A. Waheed Main CFD Forum 1 November 2, 2005 05:24
Contour plotting with origin or matlab M. A. Waheed Main CFD Forum 0 November 1, 2005 03:42
Tecplot problem of plotting boundary in contour mafoi Tecplot 1 April 5, 2005 07:43
