Head loss in sudden expansion: how evaluate it numerically |
May 26, 2018, 12:31 |
nbdy
Rep Power: 8 |
I'am stuck, i a need to evaluate the head loss due to a sudden expansion. The main problem is : i can't neglige the regular head loss... So, how can i evalute only the head loss due to the sudden expansion? The final goal is to compare the result between CFD solution and correlation. P.S: I apologize if i posted in the wrong forum. Thanks, |
June 4, 2018, 10:15 |
Reviewer #2
Rep Power: 11 |
You can simply compare the total pressure difference before and after the contraction.
Thanks |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 15:43 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
How to deifmne head loss co effcint ? | Angelina | FLUENT | 1 | February 8, 2006 10:41 |
How to deifmne head loss co effcint in cfx? | Angelina | CFX | 4 | February 7, 2006 14:14 |
Pressure loss due to sudden expansion in pipe flow | Ahmed | FLUENT | 0 | January 2, 2006 11:01 |
