How to validate internal pressure pipe with Fluid-Structure Interaction?
Old   May 21, 2018, 14:59
Lightbulb How to validate internal pressure pipe with Fluid-Structure Interaction?
mostafa
mostafa.sh is on a distinguished road
I would like to validate an article with certain internal pressure in a pipe (no inlet & outlet) with FSI method so that instead of a certain internal pressure, liquid will cross over the pipe.
the problem is how to apply boundary condition such as velocity and pressure inlet and velocity and pressure outlet for this condition.
mostafa.sh is offline   Reply With Quote
Old   May 21, 2018, 15:40
mostafa
The structure is a corroded pipeline that a certain internal pressure cause to fail the pipe. there are no inlet and outlet.
I need to create FSI for this model. so that instead of a certain internal pressure, the liquid will cross over the pipe.
I would be grateful if someone can advise me on how to do that.
Thank you very much.
Old   May 23, 2018, 07:32
mostafa
any idea??
fsi
pisoFOAM (LES) - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 January 11, 2018 17:39
Fluid structure interaction with VOF method utilized in fluent? mxl9549 FLUENT 0 July 22, 2016 14:39
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 19:57
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Fluid Structure interaction prince_pahariaa FLUENT 3 March 19, 2013 13:16
