External Radiant Temperature
Old   May 16, 2018, 09:20
Default External Radiant Temperature
Boris
Borisw37 is on a distinguished road
I'm using FloThermXT to model an electronic enclosure that will be mounted outdoors.
One of the setup parameters is called "External Radiant Temperature".
Could somebody please clarify what that is?
Shouldn't it be the same as ambient air temperature?
Thank you,
Boris.
Borisw37 is offline   Reply With Quote
Old   May 16, 2018, 13:19
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Thank you,
Boris.
The radiant temperature assumes that there is a body with the temperature to be given which is in radiation balance with the surface of the b.c. This may be very different from the ambient temperature.
Imagine or try out: Hold your hand in the near of a bulb. You feel the ambient temperature. Switch on the bulb. You feel the additional radiant temperature. If you switch off the bulb again you will determine that the ambient temperature did not change noticeable..
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 16, 2018, 15:34
Boris
Thank you for the response. It all makes sense.
How do I determine what "typical" outdoor radiant temperature is?
Old   May 17, 2018, 01:25
piu58's Avatar
Uwe Pilz
The typical radiant temperature is the one of the air.
Differences are after sunset at clear night sky when surfaces cool faster than the air. Or warm walls at night - the wall cools much slower. If you think about it you find a few examples.
Uwe Pilz
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
External wall heatflux temperature Naresh yathuru OpenFOAM Programming & Development 1 June 22, 2015 03:53
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 06:56
external radiation temperature calculation apostolos FLUENT 0 January 19, 2008 13:02
External Radiation Temperature Vedavyasa M FLUENT 0 November 12, 2007 06:15
